40-216 volume control motor
My 40-216 volume control motor just hums/buzzes. Removed and it spins freely. I have gone over everything in its control circuit. The caps and resistors are good, the trans winding resistance is dead on. Though it's putting out 28.5v at 115v, 29.7v out at line voltage. Philco parts says 21.4v out at 115v, but I don't think that's what's causing it not to work. The 2 sets of motor windings resistance match. Both at 12.9 ohms. Did a bench set up to test the motor and after a few power ups it started to turn, but slowly. It got hot so did the cap. I'm at a lose. I don't know the specs of the motor winding resistance, as said the 2 sets match. But it could be the problem.  Has any one run into this before?
The windings look pretty good. Are there scraping marks on the armature or the inside of the field. I have seen where the bearings are worn or off center and spin freely when off but when powered up the armature is pulled to the side and is jammed.
philco predicta
Philco 91 code 221
Philco 91 code 221
Philco 91 code 221
Hello Keith, great news !! Sincerely Richardradiorich — 02:14 AM
Finally, got the antenna fixed (repaired some broken wires) and have the radio playing. I've got four different schemat...keith49vj3 — 09:38 PM
Bob, Nice radio.  I’ve not seen one before.  Keep us updated!Joe Rossi — 07:56 PM
Phioco 90 Power Transformer Wire Colors
Thanks for adding that information.klondike98 — 06:09 PM
Although I have used this site as a resource for a number of years this is my first post.   I am restoring a Model 90 si...vincer — 05:02 PM
There are currently 1524 online users. [Complete List]
» 2 Member(s) | 1522 Guest(s)
