Power supply design needed from master designer Terry
Success! This thread lapsed for a bit as Terry and I were PM'ing back and forth, but today I finally finished the radio and it actually plays clear and strong! I could not have done it without Terry's help, guidance and expertise. He has the patience of a saint and the knowledge of a scholar and we are so fortunate to have him on the Phorum. My hat is off to you, my friend!
For those following along, on his original Power Supply design, the only changes made were:
The IN4007 diode was replaced with a Full Wave Bridge Rectifier for the HV
TWO IN4004 diodes for the Filament side were used in parallel to get 3A out of them.
The LM317T Adjustable Voltage Regulator was replaced with a LM317K, along with the heat sink that was designed for it, and heat sink paste to dissipate the heat. VERY important as it gets very hot otherwise. It's rated for 1.5A and the radio itself is 1.35A so it's getting close to it's limit.
I used a 10K mfd @ 50v e-cap instead of the 5K mfd , 20v that Terry specified, as I had one on hand.
For the voltage divider resistors, I used a 50 ohm on top, and a 10K ohm on the bottom, which calculated to 139v output.
It's also VERY important to have a good ground and keep the leads as short as possible. I had a terrible garbled sound problem that was all related to my having everything just "gator" wired together prior to mounting it in the enclosure. Once everything was properly soldered, it plays nice and clear.
In an unrelated problem, the bias cell batteries were naturally dead, so I tried dropping them in boiling water to recharge them. It kinda worked, but I was only getting .8 volts out of them. So I made a copper plug for the cups and a surround to isolate the sides of the battery (which are positive) from the sides of the cup and replaced all of them with #13 hearing aid batteries. Those are 1.45 volts, more what the original ones should have been.
So here are some pics of the power supply in process:
And here are some pics of the radio itself and the power supply mounted inside the cabinet:
Anyone who has a farm set they'd like to get up and running on AC without batteries, hang on to Terry's design. It's a handy thing, works like a charm, and is a fun little project to build!
I re-drew the original schematic, and modified it to use on this radio. Above is the standard Power Supply as designed by Terry (Radioroslyn) for use with 90V B supply and 1.5V A supply sets. I used this design on my Philco model 39-70
Below is the modified design for this Silivertone using a vibrator power supply:
Never said I was good at drawing  Icon_lol
When I was a kid, they did not recycle cars. they buried them in the dumps. TI had grabbed several cer radios out of these. one of the best performers was the Motorola used in the 40s Dodge and a Philco Studebaker from the early 50s. I used to just power them from the 6V windings of a TV power transformer. They worked fine. The issue here is that the tubes in the Silvertone are directly heated and can't tolerate AC.
Philco Phanatics will know there was a series of 1942 consoles and chairsides that actually used Philco Car Radios rewired to take line voltage power transformers instead of the vibrator and step up unit. These were car radios with no car, as the 1942 car production was stopped due to the war.
There are currently 1823 online users. [Complete List]
» 1 Member(s) | 1822 Guest(s)
