Philco TH-1
Could you tell me what type of wood I'm dealing with? Any accent or areas where darker lacqure were used? Appropriate style grill cloth? And where do you find those small staples used to hold the plastic dial cover in place? Thanks for the advice.
David Woodward
Hi
For the cabinet colors, I suggest Medium Walnut for the top, front panel and sides; Medium Dark Walnut for the trim between the front/top and sides, and along the bottom edge trim.
Appropriate grille cloth is Pattern #14 from Radio Grille Cloth Headquarters.
Sorry, can't help you on the staples...maybe someone else will offer a suggestion.
Nice job on the battery, Bob. Can the box be opened to replace the 9 volters?RodB — 11:32 AM
Thank you for the detailed response MrFixr. To clarify, the hum starts when the tubes are fully warmed up, and goes a...sq65 — 09:15 AM
MrFixr The chassis, if there is no ground pin in the AC plug, due to the Y-caps from L/N to the chassis, is at 60VAC re...morzh — 08:47 AM
schematics
thanks I'll try the polar caps seperatelymseno — 07:38 AM
Hi SQ55, A strange issue indeed!  Just so I have you straight, on a dim bulb you get normal operation after the set warm...MrFixr55 — 12:44 AM
schematics
I think mseno is talking about cap# 27 which is a multisection but in a paper tube. In cases like that I've usually be ...klondike98 — 11:25 PM
schematics
Ohrenet  :roll: For their price I would chase a fly in a field.  :twisted:Vlad95 — 11:21 PM
A bit more work on the Motorola. I got the repro battery together right up until I realized the snap clips on the top o...klondike98 — 10:45 PM
schematics
Often restuffed. If a twistlock, Hayseed Hamfest makes modern replacements. morzh — 09:18 PM
schematics
Looking for a multi-sectional 8+16 mfd cap. Can't find any suppliers that carry it.mseno — 08:45 PM
There are currently 1157 online users. [Complete List]
» 2 Member(s) | 1155 Guest(s)
