M3850T Philco / Ford
I just acquired a "Philco / Ford M3850T" and I am looking for a schematic.  I've tried PhilcoRadio.com and any other sources I could think of but keep coming up empty.  Sams Photofact has something but I think it's wrong.
Hi and welcome,
I took a look around but didn't see much either. Seems it circa 1966 but not listing for that particular model. Bare in mind that just about all the set we discuss are from 1928-1960 and most vacuum tube. Sam's might be only source for info.
Good luck!
Thank you so much for the reply, Terry. I sincerely appreciate your time, and I'll keep digging. It may be that an old fashioned visit to my local library is in order!
Peter; I found an old thread on the ARF, I was wrong about when Rogers took over DeForest Crosley, it looks like it wa...Arran — 06:15 AM
Thank you Arran, this is very interesting information. With your permission, I will definitely use it when I make a vide...RadioSvit — 04:14 AM
Peter; For a start your DeForest Crosley 6D632 was a 1936-37 model, and I believe it had six tubes, and 3 wave bands,...Arran — 03:07 AM
AES type of Battery Eliminator has hum in B+
This is interesting, they actually designed the B+ side with some form of voltage regulation, I think? Most of the B+ su...Arran — 02:21 AM
They are trying to use a regulator. Essentially it is an LDO schematic. LDOs are supposed to greatly reduce ripple, so t...morzh — 12:11 AM
So, I just built a 90 volt 40ma battery eliminator for a farm radio and had to use 1000 mfd for the input filter cap to ...RodB — 10:31 PM
Caps of 1,000 uF 250V are about $7 in Mouser. C1 could be increased. A NTC inrush limiter could be employed to limit t...morzh — 10:24 PM
Bruce B — 09:41 PM
Bruce Could you post the schematic if this power supply?morzh — 09:31 PM
Hello All, I have built a battery eliminator using the most popular AES K101a. Using plans and all the AES parts  order...Bruce B — 09:27 PM
There are currently 1335 online users. [Complete List]
» 1 Member(s) | 1334 Guest(s)
