Philco 37-660 chassis question
I am looking for parts for this chassis and was wondering which other models used the same design as the 37-660.
I am trying to locate a replacement for the band select lever.
Bill
Bill, your best bet is to look here and compare specs. I'd imagine without looking, that many sets use the same switch. Quite a job to change out I might add with one of these "sub-chassis" sets.
http://www.nostalgiaair.org/Resources/303/T0000303.htm
EDIT: From what I can tell, your switch is unique to this set. The following part numbers are used
antenna rg(range) sw(switch)
42-1202
RF rg sw
42-1203
Oscillator rg sw
42-1204
Indexing plate & shaft
42-1186
If I'm reading this correctly, I couldn't find any other set using the same part numbers.
-Brian
If you collect or are interested in antique telephones, please visit Classic Rotary Phones
http://www.classicrotaryphones.com/forum/index.php
Thanks for your response. It looks like I may have to try and rebuild it. I have been asking around and haven't located a replacement for it.
Bill
philco predicta
Philco 91 code 221
Philco 91 code 221
Philco 91 code 221
Hello Keith, great news !! Sincerely Richardradiorich — 02:14 AM
Finally, got the antenna fixed (repaired some broken wires) and have the radio playing. I've got four different schemat...keith49vj3 — 09:38 PM
Bob, Nice radio.  I’ve not seen one before.  Keep us updated!Joe Rossi — 07:56 PM
Phioco 90 Power Transformer Wire Colors
Thanks for adding that information.klondike98 — 06:09 PM
Although I have used this site as a resource for a number of years this is my first post.   I am restoring a Model 90 si...vincer — 05:02 PM
There are currently 1488 online users. [Complete List]
» 1 Member(s) | 1487 Guest(s)
