Restoring a 40-180
Hello folks ,and thanks again for adding me. I am in the beginning stages of trying to revive a 40-180 for an old friend. His grandparents bought it new  ,and I'm really hoping I can get it working for him. I have just started replacing ,caps , resistors. I was told I could use larger value electrolytics ,so I'm using 22uf.
I have a couple of questions here in the early stages.
#1: How can I safely remove the pushbutton ,and coil assemblies so I can access the components underneath?
#2: The OT on this unit really confuses me. I'm used to OTs on guitar amps. This one has primary wires ,but no secondary wires to the speaker. How does that work if I need a replacement?
Thanks in advance ! Tom
Can you post a photo showing the wiring for the output transformer from beneath the chassis? You should have four wires going to the speaker - two from the transformer for the voice coil and two from the power supply for the field coil.
DaleHCook, There are only three wires ,and a ground I see on the OT.  Two go to the power tube plates ,and the center goes to 16uf cap ,and the field coil according to the schematic.
Actually, there are three insulated wires, a bare wire, and another bare wire which you may not see since it is soldered to the frame (side) of the audio output transformer (56).
The three insulated wires are the primary of the output transformer.
The bare wires (one you see, one you don't) are the secondary of the output transformer.
See partial schematic below.
Thank you Ron. I thought it was just the one bare wire. (thought that was just a transformer ground) Would make more sense now.  I thought I checked those ,and the both showed ground ,but I'll check again.  I know the resistance reading on the primaries is low compared to what the schematic says ,but the leads are still soldered.
Philco 91 Restore Code ??
I measured the current through the resistor I am using as a replacement for the speaker field coil and got 40ma. So that...dconant — 02:32 PM
No I'm not saying I don't own a DMM. I have a CCC one (Thsinde 18+). I forgot that could read caps. I did purchase a Flu...dconant — 02:28 PM
Are you telling me you do not own any decent DMM, that can measure capacitances from a few pF and up? Even todays CCC (C...morzh — 01:44 PM
Restoring Philco 96
Well, selectivity today, with stations disappearing, is not such a problem for TRF as it likely used to be. Although wh...morzh — 01:42 PM
Mike I did that already and can't really get any kind of reading. My little Honeytek A6013L reads 0 on all scales. One s...dconant — 01:38 PM
New member
Well, to be frank, when it comes to radios, especially the older types, a person with no electronic background could be ...morzh — 01:33 PM
Restoring Philco 96
Thanks for mentioning the video you had uploaded. Somehow I missed that post. Just watched your video, and it sounds to ...jrblasde — 01:28 PM
Restoring Philco 96
Joseph well, for now we will have to get by the video I have made, as the final video would not be made before I get a ...morzh — 01:04 PM
Ron It sure does. Only there is no hole. Dconant Here's the idea: if you haven't done so already (I am la...morzh — 12:55 PM
Maybe some electrical tape? Has worked for me in the past an low cost. DavidDavid — 12:47 PM
There are currently 1137 online users. [Complete List]
» 3 Member(s) | 1134 Guest(s)
