Philco All-Purpose Set Tester Model 048A
Group: Some of you may have seen the pristine 1936-ish model 048A All Purpose Set Tester on ebay recently. I was the winner of that auction and probably paid too much, but I couldn't resist.
This unit looks like it was used briefly when it was new and then was tucked away for 85+ years and then found in an attic when a house was being cleaned out. Anyhow, the wooden cabinet is in excellent shape with the original handle looking like new and the Philco logo on front being unblemished.
It included all of the probes that originally came with it - and the hang tags that attached to the switches when it was new (Nathan S. I will scan those for inclusion in the library) and the best of all - all 3 of the original Philco P-155 "C" batteries (22.5 V each) still in place. They are awesome - the tar in the top has the voltages stamped in them. The 1.5V "flashlight battery for the ohmmeter is a 1930s Burgess uni-cell replacement with a 1933 patent date so it too has been there a long time. No mods have been done to this one and it is as original as they come. so many of them were converted to using battery eliminators - this was the first one I have seen that was not modified. If there is every a Philco museum, this one should be in it. -- Andy
Andy Sorrell
Palmyra, Virginia
Andy, that's a beauty, congratulations Icon_thumbup
Very nice!
Icon_thumbup
hello Andy,
That is a great find and anyone who is a true Philco or test equpment collector would enjoy it .
Peter; I found an old thread on the ARF, I was wrong about when Rogers took over DeForest Crosley, it looks like it wa...Arran — 06:15 AM
Thank you Arran, this is very interesting information. With your permission, I will definitely use it when I make a vide...RadioSvit — 04:14 AM
Peter; For a start your DeForest Crosley 6D632 was a 1936-37 model, and I believe it had six tubes, and 3 wave bands,...Arran — 03:07 AM
AES type of Battery Eliminator has hum in B+
This is interesting, they actually designed the B+ side with some form of voltage regulation, I think? Most of the B+ su...Arran — 02:21 AM
They are trying to use a regulator. Essentially it is an LDO schematic. LDOs are supposed to greatly reduce ripple, so t...morzh — 12:11 AM
So, I just built a 90 volt 40ma battery eliminator for a farm radio and had to use 1000 mfd for the input filter cap to ...RodB — 10:31 PM
Caps of 1,000 uF 250V are about $7 in Mouser. C1 could be increased. A NTC inrush limiter could be employed to limit t...morzh — 10:24 PM
Bruce B — 09:41 PM
Bruce Could you post the schematic if this power supply?morzh — 09:31 PM
Hello All, I have built a battery eliminator using the most popular AES K101a. Using plans and all the AES parts  order...Bruce B — 09:27 PM
There are currently 1167 online users. [Complete List]
» 1 Member(s) | 1166 Guest(s)
