Philco 89 Lower Frequencies
Rob I use a business card as it is stiffer and a little more course.
Don, you are correct! But these are the numbers the winding w/162t = 7 ohms but the winding w/96t = 24 ohms. The point I'm getting at is it's difficult guess if a coil is good or bad based on it's resistance unless it's pretty high. The 24 ohm winding is fairly small compared to the 7 ohm. Logic would cause one to think that a small winding would a lower resistance, maybe maybe not.
As for the tuning cap ground as Rod said the brass spring fork looking things that slip into the groove on the rotor of the tc. Those need to be clean and the attached wires soldered to chassis ground. I don't know if the 89 has it but on the later model sets one of the 1/4 hex screws caps is filled w/solder and copper braid is soldered to the screw cap and to the chassis. I've also seen done as a repair were a length of braid has been soldered to the rotor shaft and then to the frame the tc. Ron had recommended on these older set to remove the tc and replace the wires that some time they fracture under the insulation and can cause intermittent problems.
Just some thoughts on the issue.
Restoring Philco 96
Restoring Philco 96
Restoring Philco 96
My Philco 37-116 Restore
I managed to open up the Expander Unit and replace the grid cap wires. Tested the connections found they looked good and...dconant — 12:19 PM
610B Oscillator Questions
I've included a picture of the 'actual' schematic I created. I double checked several times and it appears to be accur...Tubester — 09:26 AM
First Radio restoration
Hi, welcome. I did a 40-130 a few years ago. I was very surprised at how well it performed. Just take care with that sp...Stan the Man — 07:20 AM
Restoring Philco 96
Situations of the like are not pleasant. Life is inevitable. Best of luck to you. I have two 76 chassis, in different ...Stan the Man — 07:12 AM
There are currently 1896 online users. [Complete List]
» 1 Member(s) | 1895 Guest(s)
