Bakelite crack repair - what is best epoxy?
Starting on a Philco 48-1401 Boomerang radio/phonograph.  It has one crack on the left side running from the speaker opening to and through the front edge.  I will be able to clamp it side to side, but the crack will remain about 1/16" and will need to be filled.
I'd really like to only do this once, so I'm looking for recommendations for the best epoxy and practice to use.
I plan to finish the repair with a patch underneath using some fiberglass cloth covered with the epoxy.
I'd appreciate your feedback.
73
Bob
de371
JB Weld. I use the 5 minute for short gaps and 30 minute for longer ones.
I always used two part epoxy, the 24 hour cure stuff is stronger, it's also clear, JB Weld is usually grey. I haven't found fiberglass cloth to be necessary for repairing a crack, though it would be with filling a large chip or hole.
I'm with Arran, but I use even stronger epoxy with a 72 hour cure. It is sold to knife makers for bonding wooden handles to knife tangs, eliminating the need for fasteners.
Thanks everyone. I appreciate you sharing your experience and looks like I'll work with the 24 hr two part clear epoxy. The crack is a full break about 4 inches long. The front edge will mate perfectly but there was a loss of bakelite "dust" along the rest of the length which will keep a crack about 1/16" or less. The two part clear should help to fill it in.
Peter; I found an old thread on the ARF, I was wrong about when Rogers took over DeForest Crosley, it looks like it wa...Arran — 06:15 AM
Thank you Arran, this is very interesting information. With your permission, I will definitely use it when I make a vide...RadioSvit — 04:14 AM
Peter; For a start your DeForest Crosley 6D632 was a 1936-37 model, and I believe it had six tubes, and 3 wave bands,...Arran — 03:07 AM
AES type of Battery Eliminator has hum in B+
This is interesting, they actually designed the B+ side with some form of voltage regulation, I think? Most of the B+ su...Arran — 02:21 AM
They are trying to use a regulator. Essentially it is an LDO schematic. LDOs are supposed to greatly reduce ripple, so t...morzh — 12:11 AM
So, I just built a 90 volt 40ma battery eliminator for a farm radio and had to use 1000 mfd for the input filter cap to ...RodB — 10:31 PM
Caps of 1,000 uF 250V are about $7 in Mouser. C1 could be increased. A NTC inrush limiter could be employed to limit t...morzh — 10:24 PM
Bruce B — 09:41 PM
Bruce Could you post the schematic if this power supply?morzh — 09:31 PM
Hello All, I have built a battery eliminator using the most popular AES K101a. Using plans and all the AES parts  order...Bruce B — 09:27 PM
