Threads: 37
City: Marion
State, Province, Country: NY
I have seen a You Tube video where the guy uses solvent based contact cement, the kind you use for veneer gluing, to repair rips in the cone sans any paper. What do we think of that idea. I tried one once and seemed to sound good when it was done.
Threads: 32
City: Wellborn Florida
Contact cement is good for small stuff or rubber cement. Big stuff Elmer's white glue (school glue) and coffee filters on the back side have repaired some big rips around the outside of the cone. Take a black felt tip marker to hide the white filter. David
Threads: 158
City: Westland, MI
I've used Aleene's Permanent Fabric glue. Dries clear and flexible, and under $10.00. Take care and BE HEALTHY! Gary
Threads: 44
City: Roseville, MN
Just remember, if your repair is in the main cone, the cone is intended to be stiff, so your repair should also be stiff. If the repair is on the flexible edge then your repair should be flexible.
Threads: 2
City: Muhlenberg County
State, Province, Country: KY
There are as many adhesives to use as there are people who repair their own cones. I use Trident Neoprene Cement and have had great luck with it. It is markedly less expensive than most of the same make up.
When you unsolder what has been soldered before the unsoldering, the unsoldering of the soldered is what will be.
Threads: 54
I have used the solvent based general purpose contact cement for years, with few issues, the Bonafede speaker cement is pretty much the same but is tinted black to blend in with the paper. I think that the water based contact cement might work as well, as would the fabric glue, flexibility is what you need for repairing the hinge/surround since it has to move, along with the cloth spiders. One thing you should NOT use is silicone, that belongs around the bathtub not on a speaker cone, I don't know where that idea came from in it being useful on speakers but I have had to scrape the rubbish off more then once to repair a speaker properly.
Threads: 37
City: Marion
Hi Arran, I know what you mean about the silicone. I have a speaker that someone tried to repair with the stuff. They made a total mess of it but I managed to get most of it off. It was one of those red Stromberg Carlson speakers. Talk about an ugly mess.
Dan
Threads: 117
City: Omak
State, Province, Country: WA
Hello Guys,
Yes, I agree with you Arran I like using good old Elemer's Rubber Cement and I also use Weldwood Contact cement .
the last speaker repair that I had was from my Zenith model 908 radio someone had poked a hole in it .
Threads: 26
City: Monticello
State, Province, Country: Illinois
I have been using Elmers Clear School glue and coffee filter paper for year with great success.
Philco's: 86 Low Boy, 90 High Boy, 95 High Boy, 76 High Boy, 112X Console, 118X Console, 41-265 Console, 41-608P Console, 52GC, 370 LZ, 512, 20 Baby Grand, 70 Baby Grand, 71B, 52B, 118B, 60B, 84B, 610B, 37-89B, 38-10T, 38-35B, 41-221CI, 42-321T, 46-1203
48-214, 48-206, 49-506
Thanks for the replies. It's not the really the hum that I am after. Just trying to understand why only the shortwave ba...Tubester — 04:01 PM |
Restoring Philco 96
70 and 90 are Superhets, but at least the 2x45 model of 90 uses the Plate detector (and so does 70).
Also the Atwaters,...morzh — 03:28 PM |
Restoring Philco 96
Morzh, Prayers for your mom. I am sure that there was enough pain living through the Holocaust as a child. I pray dail...MrFixr55 — 02:19 PM |
Hi Dan,
Divide and conquer. First off trry to differentiate between 60Hz and 120 Hz hum. 120 Hz hum has a higher pit...MrFixr55 — 01:49 PM |
Restoring Philco 96
Yes, other than takin a toll on your back, they are undeed way more repair friendly than many other Philcos.
To me, som...morzh — 01:04 PM |
If the wires look like they were this way from the factory (very neat and very dull soldering joints), I'd leave them be...morzh — 12:58 PM |
My Philco 37-116 Restore
I managed to open up the Expander Unit and replace the grid cap wires. Tested the connections found they looked good and...dconant — 12:19 PM |
610B Oscillator Questions
I've included a picture of the 'actual' schematic I created. I double checked several times and it appears to be accur...Tubester — 09:26 AM |
First Radio restoration
Hi, welcome. I did a 40-130 a few years ago. I was very surprised at how well it performed. Just take care with that sp...Stan the Man — 07:20 AM |
Restoring Philco 96
Situations of the like are not pleasant. Life is inevitable. Best of luck to you.
I have two 76 chassis, in different ...Stan the Man — 07:12 AM |
There are currently 1898 online users. [Complete List] » 1 Member(s) | 1897 Guest(s)
