  • 1 Vote(s) - 3 Average
Emud T7 Power Transformer.
I wanted to ask if anyone knows the values and voltages for the power transformer in an Emud T7 radio? The one in my recapped T7 fried a couple years back and my friend said there is a chance he has a transformer that might work when I bought the SABA off him. He found a few boxes of power transformers when he was cleaning out his shop before the auction and took them home.
Jayce;
  From what I can tell the Emud T7 is a seven tube set, but unlike most West German radios from that era it has a tube rectifier similar to a 6X4. You will have to look up the heater current of each tube, and add them together to figure out what you need for the 6.3 volt heater winding. I don't know what the voltage rating is for the high voltage winding, but it would be center tapped because of the tube rectifier, so likely 300-0-300 volts, or something like that, at probably 120 ma. These are all guesses, the best way to find out if find the service info for this set, and a parts list if you are lucky. If it has taps for different primary voltages you won't have to worry about that in the replacement, so that makes finding a new or used replacement easier.
Peter; I found an old thread on the ARF, I was wrong about when Rogers took over DeForest Crosley, it looks like it wa...Arran — 06:15 AM
Thank you Arran, this is very interesting information. With your permission, I will definitely use it when I make a vide...RadioSvit — 04:14 AM
Peter; For a start your DeForest Crosley 6D632 was a 1936-37 model, and I believe it had six tubes, and 3 wave bands,...Arran — 03:07 AM
AES type of Battery Eliminator has hum in B+
This is interesting, they actually designed the B+ side with some form of voltage regulation, I think? Most of the B+ su...Arran — 02:21 AM
They are trying to use a regulator. Essentially it is an LDO schematic. LDOs are supposed to greatly reduce ripple, so t...morzh — 12:11 AM
So, I just built a 90 volt 40ma battery eliminator for a farm radio and had to use 1000 mfd for the input filter cap to ...RodB — 10:31 PM
Caps of 1,000 uF 250V are about $7 in Mouser. C1 could be increased. A NTC inrush limiter could be employed to limit t...morzh — 10:24 PM
Bruce B — 09:41 PM
Bruce Could you post the schematic if this power supply?morzh — 09:31 PM
Hello All, I have built a battery eliminator using the most popular AES K101a. Using plans and all the AES parts  order...Bruce B — 09:27 PM
