Which rubber parts for Philco 37-640
Hello Phorum Membbers:   For the Philco 37-640 tombstone radio I am trying to restore, which  rubber gromets should I order for the chassis bottom to cabinet bottom(PHILCO chassis supports).  I believe that the mounting screws go through them.  Should I order CH32 or CH4 from Renovated Radios?  Thanks, John
Hello John,
Well Have you tried to measure the original one ?
Don't quote me but I believe it is CH4
Sincerely richard
Thanks Richard for the replay. Unfortunately, I had thrown the old pieces away but they were so distorted and smashed, I don't know if I could of even gotten a true measurement.--John
AES type of Battery Eliminator has hum in B+
They are trying to use a regulator. Essentially it is an LDO schematic. LDOs are supposed to greatly reduce ripple, so t...morzh — 12:11 AM
So, I just built a 90 volt 40ma battery eliminator for a farm radio and had to use 1000 mfd for the input filter cap to ...RodB — 10:31 PM
Caps of 1,000 uF 250V are about $7 in Mouser. C1 could be increased. A NTC inrush limiter could be employed to limit t...morzh — 10:24 PM
Bruce B — 09:41 PM
Bruce Could you post the schematic if this power supply?morzh — 09:31 PM
Hello All, I have built a battery eliminator using the most popular AES K101a. Using plans and all the AES parts  order...Bruce B — 09:27 PM
Need to purchase Old Philco Radio Knobs
Hello Paulo , I have Philco 38-10 too that I am restoring the chassis is almost complete ! Far as my cabinet It is in ...radiorich — 09:00 PM
HI MORZH Thank you so much for this tip. I will try contacting to him. thanks a lot, Best Regards, Paulo Alo...palonso — 05:27 PM
Refinishing Ideas
We just had the discussion on the GoJo. It is no longer sold, but Goop is, and those two are very close. I use Goop and ...morzh — 11:58 AM
+1 on what Arran suggested. In my case, my cabinet had the usual scratches and nicks, except the top had water damage pr...462ron — 08:36 AM
There are currently 1475 online users. [Complete List]
» 1 Member(s) | 1474 Guest(s)
