Canadian Philco 37-361
How many Bakelite  blocks does a Canadian Philco   model 37-361 have ?
 I might be doing a restoration on one
Thanks
 Dan in Calgary
   Living in Calgary Alberta
Dan;
  I don't think that there are that many if the Toronto plant followed what they did in Philadelphia, probably the power line cap is a Bakelite block but not much else. Most of the Canadian models shared chassis with their U.S cousins up until 1939-40, though the cabinets differed sometimes, like my model 3118B. They are not really that had to restuff if you have to, Mike/Morzh has the technique right down.
Thanks for the information. I don't have the radio yet,but i wanted to get some information
 Dan in Calgary
AES type of Battery Eliminator has hum in B+
They are trying to use a regulator. Essentially it is an LDO schematic. LDOs are supposed to greatly reduce ripple, so t...morzh — 12:11 AM
So, I just built a 90 volt 40ma battery eliminator for a farm radio and had to use 1000 mfd for the input filter cap to ...RodB — 10:31 PM
Caps of 1,000 uF 250V are about $7 in Mouser. C1 could be increased. A NTC inrush limiter could be employed to limit t...morzh — 10:24 PM
Bruce B — 09:41 PM
Bruce Could you post the schematic if this power supply?morzh — 09:31 PM
Hello All, I have built a battery eliminator using the most popular AES K101a. Using plans and all the AES parts  order...Bruce B — 09:27 PM
Need to purchase Old Philco Radio Knobs
Hello Paulo , I have Philco 38-10 too that I am restoring the chassis is almost complete ! Far as my cabinet It is in ...radiorich — 09:00 PM
HI MORZH Thank you so much for this tip. I will try contacting to him. thanks a lot, Best Regards, Paulo Alo...palonso — 05:27 PM
Refinishing Ideas
We just had the discussion on the GoJo. It is no longer sold, but Goop is, and those two are very close. I use Goop and ...morzh — 11:58 AM
+1 on what Arran suggested. In my case, my cabinet had the usual scratches and nicks, except the top had water damage pr...462ron — 08:36 AM
There are currently 1560 online users. [Complete List]
» 1 Member(s) | 1559 Guest(s)
