Can it be used as replacement interstage trans?
I pulled my 2nd AF transformer from my 87 and found the part #3242. No luck finding it so far, but I found a 4232. From what I see the only difference is mine drives the 45 tubes by a 26 tube and the other one drives them by a 27 tube. It seems the 4232 was used in more models. I cannot find any other radio that uses the one I pulled from mine. They are both 1:4 ratio. Can it be used as a replacement?
Looking at my Philco early 30s parts catalogues, they are both 1:4 turns ratio and are used with the same "in" and "out" tube complements (27 driver to p-p 45, 47, 42 or 71-A), so I'd say it should work fine. Both even have the same mounting hole "footprint." Icon_biggrin
48-482 rear panel help
I also have one of these, again it never had a back, and no trace of one. I have been told that the pushbuttons used to ...Arran — 03:29 AM
Thanks Joseph. Hope you get to restore your 48-482 before too long!keithchip — 02:12 AM
Need Help to ID this radio 11 tube Philco
RCAs ain't no cake either.morzh — 10:32 PM
After a couple of days worth of troubleshooting my signal generator, I gave up. The oscilloscope still worked fine, so I...jrblasde — 09:51 PM
Yes, I can confirm. I bought one (haven’t restored it yet) which didn’t have a back panel.jrblasde — 09:37 PM
Try a 39-116.Radioroslyn — 09:24 PM
I remember Philco 45 being awkward. If I am not mistaking it for some other set. I think there is a phenolic board, or e...morzh — 08:49 PM
If you want a radio that's difficult to work on, get a 37-620. The one side of the chassis is packed pretty tightly and ...Greg — 07:29 PM
Philco 16 is not intimidating at all. Despite being an 11-tuber. 37-116 is indeed intimidating. 16 has good space unde...morzh — 04:11 PM
Thanks for the responses Gary and Bob. I'm a little surprised that there's no back panel - although I know older Philco'...keithchip — 04:09 PM
