SHADOW METER ADJUSTMENT
According to a photocopy of the owner's manual I have for my 37-670, the shadow meter supposedly is user adjustable. The only thing I can see that could possibly be adjusted is a knurled plastic piece that also serves as the back of the coil, in front of the lamp assembly. This does not move with gentle pressure and I am afraid to exert force in case I'm barking up the wrong tree here. Can anyone help?
Yes, that is the actual coil, and it can be moved. It may be stuck after decades of not being moved, so proceed carefully.
Details here:
http://www.philcorepairbench.com/tips/svctip01.htm
Thanks,Ron! I started to gently rock the coil back and forth, and sure enough it moved -- albeit very stiffly. When I eventually get the radio together and back in the cabinet I'll be able to adjust the shadow -- assuming the coil isn't open.
I really appreciate the help.
Eric Strasen
Need Help to ID this radio 11 tube Philco
Welcome, the radio looks intimating 11 tubes, wish you well.Jimradio — 07:49 AM
Hi Dan, it’s been 10 years since I restored the electronics on my 37-116 so I’m going on some foggy memories. I remember...462ron — 07:37 AM
Yes the 16B as morzh pointed out. Specifically its the January 1935 model version of the 16B. There are a couple earli...klondike98 — 11:51 PM
48-482 rear panel help
Welcome to the Phorum, keithchip! How far you take a radio on cabinet restoration is a matter of personal preference. ...GarySP — 11:28 PM
I've recently finished the internal restoration of a locally purchased Philco 48-482. The cabinet is in ok shape except ...keithchip — 10:28 PM
Welcome to the Phorum, Ken! Lots of help here for all of your restoration questions. Take care and BE HEALTHY! - Gar...GarySP — 07:59 PM
Thank you. I went to your online library and found 2 schematics. I will download and compare to components!Ken D. — 06:31 PM
It is a 16B tombstone.morzh — 06:13 PM
David - sorry, I reread your post and finally saw THD - now the % figures make sense. Thanks for explaining. The PSU...EdHolland — 06:06 PM
Hi Everyone, New member but have been reading this for awhile for tips! Vaccum tubes were before my time so bear with ...Ken D. — 06:03 PM
There are currently 375 online users. [Complete List]
» 3 Member(s) | 372 Guest(s)
