zenith 8D625 radio
While at a flea market seeing the antiques sign I stumbled on a rugged old radio! After my inspection I had seen the dial with the hard wood. Then the dial I had seen the meters under the kilocycles dating this radio arount the late 1930s. So happily I handed over my $10 Icon_biggrin. After opening the back cover I saw the amazing antenna. Next the tubes, they weren't loktals they were earlier so I felt glad with my purchase. So after replacing the cord it worked with amazing quality!!!
So if you see a zenith 8D625 I would buy it for the right price.
http://www.instructables.com/file/FFYGOO9GFRWRAES/
Sounds like you got a great deal.
It might be a time bomb though, give some thought to replacing the electrolytic and coupling capacitors to keep the set going a few more decades.
yea there like 40 caps not to mention the cost of them Icon_biggrin
I've never heard of an 8D625. Must be rare Icon_smile There's a 5D625 that looks like the one in the photo and is very common but it doesn't have 40 caps!
Here's the schematic for the 5D625. (Hint - the first digit in that era of Zenith model numbers indicates the tube count)
<!-- m --><a class="postlink" href="http://www.nostalgiaair.org/PagesByModel/926/M0024926.pdf">http://www.nostalgiaair.org/PagesByMode ... 024926.pdf</a><!-- m -->
$10 was a good deal.
I'll parrot the advice about recapping.
<!-- m --><a class="postlink" href="http://www.instructables.com/file/F16OJFQGFRWRIY1/">http://www.instructables.com/file/F16OJFQGFRWRIY1/</a><!-- m --> <!-- m --><a class="postlink" href="http://www.instructables.com/file/F7F334DGFRWRIYS/">http://www.instructables.com/file/F7F334DGFRWRIYS/</a><!-- m --> here are some photos! Insted of 5 tubes there are six tubes regarding the schematic. I don't know if ther paint lable or modifications were made? anything on this? thanks philcoradio1234
With regard to the speaker, unless the cone is so brittle that it crumbles as soon as you touch it I would try to repair...Arran — 04:07 AM
That silver can capacitor is an aluminum electrolytic. You should replace it with an aluminum electrolytic with the valu...RodB — 11:46 PM
There are currently 427 online users. [Complete List]
» 2 Member(s) | 425 Guest(s)
