Help Identify.....
Is this a Philco radio? I spent some time going through the gallery to no avail. Can anyone help me Identify this set?
Thanks!
Lawrence
[Image: http://i139.photobucket.com/albums/q303/...Philco.jpg]
[Image: http://i139.photobucket.com/albums/q303/...ilco_2.jpg]
Hi Lawrence, and welcome!
I've moved this thread to "Other Radios (Non-Philco)" since this is not a Philco set.
That's an RCA tombstone. I do not know what model it is; it looks like it is in the same age bracket as a 5T or 6T. How many tubes does it have? Looks like some tubes are missing in your set?
There should be a piece of paper glued to one side of the cabinet, on the inside, giving the model number. Of course this paper may be missing.
Thanks! It is indeed a 6T with a broken speaker grille. That's what threw me off. That and the fact that I was told it was a Philco.
Thank you for the help!
Lawrence
With regard to the speaker, unless the cone is so brittle that it crumbles as soon as you touch it I would try to repair...Arran — 04:07 AM
That silver can capacitor is an aluminum electrolytic. You should replace it with an aluminum electrolytic with the valu...RodB — 11:46 PM
