Need a speaker for an AK 318 console.
Hello Ron and Phorum readers: Need a speaker for an AK 318 console. From hole where speaker used to reside believe a 10 inch. Speaker jack in chassis is 5 prong vice the usual 4 prong you find in AK radios.
With regard to the speaker, unless the cone is so brittle that it crumbles as soon as you touch it I would try to repair...Arran — 04:07 AM
That silver can capacitor is an aluminum electrolytic. You should replace it with an aluminum electrolytic with the valu...RodB — 11:46 PM
