Can I use a rooftop TV antenna with my Philco radio?
Could I splice into an existing outside roof TV antenna and use it as my radio antenna for my 39-31- philco? I presently use the tv antenna for local channels!
Jim
New topic created by site admin. This post was not related to the thread where it was originally posted.
The TV antenna itself is unlikely to help at all with the frequencies involved. But the downlead from it might help a bit, though it is still not ideal because the downlead is vertical and, these days, is generally coax. Using the shield of the coax as an antenna might be better than nothing?
Yes. the inner wire is shielded, but I've had pretty good luck using the shield as an AM antenna. Simply making contact with the metal connector will connect your radio antenna lead with the coax outer shield.
AM 1530 Riverside Radio (my home AMT3000 station)
Thanks for the info Jepstro, I will give it a shot once I get the chassis repaired!!
Jim!
Need Help to ID this radio 11 tube Philco
Welcome, the radio looks intimating 11 tubes, wish you well.Jimradio — 07:49 AM
Hi Dan, it’s been 10 years since I restored the electronics on my 37-116 so I’m going on some foggy memories. I remember...462ron — 07:37 AM
Yes the 16B as morzh pointed out. Specifically its the January 1935 model version of the 16B. There are a couple earli...klondike98 — 11:51 PM
48-482 rear panel help
Welcome to the Phorum, keithchip! How far you take a radio on cabinet restoration is a matter of personal preference. ...GarySP — 11:28 PM
I've recently finished the internal restoration of a locally purchased Philco 48-482. The cabinet is in ok shape except ...keithchip — 10:28 PM
Welcome to the Phorum, Ken! Lots of help here for all of your restoration questions. Take care and BE HEALTHY! - Gar...GarySP — 07:59 PM
Thank you. I went to your online library and found 2 schematics. I will download and compare to components!Ken D. — 06:31 PM
It is a 16B tombstone.morzh — 06:13 PM
David - sorry, I reread your post and finally saw THD - now the % figures make sense. Thanks for explaining. The PSU...EdHolland — 06:06 PM
Hi Everyone, New member but have been reading this for awhile for tips! Vaccum tubes were before my time so bear with ...Ken D. — 06:03 PM
There are currently 375 online users. [Complete List]
» 3 Member(s) | 372 Guest(s)
