Philco 47-1230 restoration
#31
There is more info on the safety caps here
http://www.justradios.com/X1Y2capacitors.html
-Keith
#32
Early production 47-1227 sets used a bakelite block which contained two capacitors as the AC line bypass. This was changed in Run 3 to two separate mica caps.
The same change was made to model 47-1230.
A plug for Chuck: this is one example of the kind of information you can get in his service packets.
http://www.philcorepairbench.com/schematics.htm
As you have two mica caps as the AC line filter, as stated previously, they should be replaced with two X1/Y2 safety caps.
Arran. As always, the information you have provided is very valuable to me. Thank you. Yes, it is a Canadian Philco 316A...RadioSvit — 04:04 PM
Best to use the one from the library on this site, then when you refer to part 30 we know which part you are referring t...RodB — 03:32 PM
52-942
Welcome to the Phorum, Ken! The included schematic for your set is located in the Philco Library at the bottom of our Ho...GarySP — 03:13 PM
Video Source for Predicta
You can also source a used VCR and use that as a modulator to feed your DVD source into.TV MAN — 02:57 PM
52-942
Just received my 52-942. Its a handsome set. When I opened the back to examine it I noticed there are not connecting wir...Ken Arroyo — 02:54 PM
"Your radio tubes get these voltages from the power transformer secondary windings. The A voltage is supplied by th...osanders0311 — 01:40 PM
Please correct me if I am wrong, while working on this radio I noticed under the chassis where the bottom of the tubes p...osanders0311 — 01:28 PM
"BTW there's a 2.2k resistor from B+ to one of the XXL tubes so you have to identify those resistors before you rep...osanders0311 — 01:04 PM
BTW there's a 2.2k resistor from B+ to one of the XXL tubes so you have to identify those resistors before you replace t...RodB — 11:08 AM
Okey dokey, let's get on the wayback machine. Back when radios were running on batteries, they were powered by three DC ...RodB — 10:34 AM
There are currently 797 online users. [Complete List]
» 1 Member(s) | 796 Guest(s)
