Philco 90 first detector transformer open
Have the primary side of the first detector transformer (7) on schematic. If I were to rewind what length/turns of what gage wire should I use?
I think I have the info here somewhere...let me check on that and get back with you later.
That silver can capacitor is an aluminum electrolytic. You should replace it with an aluminum electrolytic with the valu...RodB — 11:46 PM
