Philco model 20 BC resistor
Was wondering does it run pretty hot near the B+ end? Mine does. Seems like it been doing it for along time. It's melted some of the tar from the filter bank on to it and the chassis and on to the resistor. Voltages look good and it plays ok too. After it's been on for a few minutes if I look closely I can see the tar that has leaked on to it bubble.
Just remember, you're running the radio with today's 120-125 VAC and the set was designed for 110-115 VAC back in the day.
The power transformer will be pumping out a higher secondary voltage.
Not real good for the longevity of the power transformer in the long run.
Use a buck/boost transformer to lower your AC voltage or a variac and see what the effects are. The BC resistor should get relativelt hot, since it's a wirewound type, but not 'boiling' hot. Your higher AC mains voltage may be a contributor.
Chuck
Have got a autotransformer hook up to it now. Running it at 90v gets warm but not bubbling.
Tnx
What I may do is remove the input capacitor so the p/s is choke input. That will drop the output voltage down.
Terry, you posted in another thread that replacing the 0.25 uF bypass caps helped lower your B-C resistor's fever; is it doing OK now?
I have a plain 20 and a deluxe 20, neither one are restored so I can't comment on how warm the B-C resistor gets. But I would not expect them to get hot to the point of roasting under normal operation.
Need Help to ID this radio 11 tube Philco
Welcome, the radio looks intimating 11 tubes, wish you well.Jimradio — 07:49 AM
Hi Dan, it’s been 10 years since I restored the electronics on my 37-116 so I’m going on some foggy memories. I remember...462ron — 07:37 AM
Yes the 16B as morzh pointed out. Specifically its the January 1935 model version of the 16B. There are a couple earli...klondike98 — 11:51 PM
48-482 rear panel help
Welcome to the Phorum, keithchip! How far you take a radio on cabinet restoration is a matter of personal preference. ...GarySP — 11:28 PM
I've recently finished the internal restoration of a locally purchased Philco 48-482. The cabinet is in ok shape except ...keithchip — 10:28 PM
Welcome to the Phorum, Ken! Lots of help here for all of your restoration questions. Take care and BE HEALTHY! - Gar...GarySP — 07:59 PM
Thank you. I went to your online library and found 2 schematics. I will download and compare to components!Ken D. — 06:31 PM
It is a 16B tombstone.morzh — 06:13 PM
David - sorry, I reread your post and finally saw THD - now the % figures make sense. Thanks for explaining. The PSU...EdHolland — 06:06 PM
Hi Everyone, New member but have been reading this for awhile for tips! Vaccum tubes were before my time so bear with ...Ken D. — 06:03 PM
There are currently 375 online users. [Complete List]
» 3 Member(s) | 372 Guest(s)
