model 20 dog bone resistor values
I want to replace the 5 dogbone resistors. I can not find the equivelent part number/codes for these parts. I would appreciate any help you can give.
Why do you need the part numbers? You can't just go down to the Philco distributor and get these anymore...
Anyway, your wish is my command:
(12) 50,000 ohms, part no. 4237
(15) 250,000 ohms, part no. 3768
(17) 500,000 ohms, part no. 3769
(18 ) 100,000 ohms, part no. 3767
(20) 500,000 ohms, part no. 3769
Here's some additional info where they are listed by wattage.
http://www.philcorepairbench.com/carbonres.htm
And if yours aren't shown in the list click on the comparison pictures link. That is handy for all old dogbones, not just Philco.
You will probably have to resort to modern values like 470k instead of 500k, etc.
GL,
Bill
thanks for your help. Ron, which site has these part numbers? I understand you don't sell them.
You aren't going to be able to find those parts any longer more than likely. I'd recommend you get modern equivilents...
Try http://www.justradios.com : http://www.justradios.com/rescart.html
Look for ones that are as close as possible in the 1W Flame Proof column. They come in packs of 5.
50k ohm would = 47k ohm
250k = 250k
500k = 500k
100k = 100k
Brian Mattson
Coon Rapids, MN
Need Help to ID this radio 11 tube Philco
Welcome, the radio looks intimating 11 tubes, wish you well.Jimradio — 07:49 AM
Hi Dan, it’s been 10 years since I restored the electronics on my 37-116 so I’m going on some foggy memories. I remember...462ron — 07:37 AM
Yes the 16B as morzh pointed out. Specifically its the January 1935 model version of the 16B. There are a couple earli...klondike98 — 11:51 PM
48-482 rear panel help
Welcome to the Phorum, keithchip! How far you take a radio on cabinet restoration is a matter of personal preference. ...GarySP — 11:28 PM
I've recently finished the internal restoration of a locally purchased Philco 48-482. The cabinet is in ok shape except ...keithchip — 10:28 PM
Welcome to the Phorum, Ken! Lots of help here for all of your restoration questions. Take care and BE HEALTHY! - Gar...GarySP — 07:59 PM
Thank you. I went to your online library and found 2 schematics. I will download and compare to components!Ken D. — 06:31 PM
It is a 16B tombstone.morzh — 06:13 PM
David - sorry, I reread your post and finally saw THD - now the % figures make sense. Thanks for explaining. The PSU...EdHolland — 06:06 PM
Hi Everyone, New member but have been reading this for awhile for tips! Vaccum tubes were before my time so bear with ...Ken D. — 06:03 PM
There are currently 376 online users. [Complete List]
» 3 Member(s) | 373 Guest(s)
