Philco 90 question
Hi all,
I am, after many years of looking, the proud owner of a Philco 90 baby grand! I have wanted this set since I was a freshman in high school, but have never found one that I could afford. The ones I've seen that I could afford were past any help I could give it. I finally found a good restorable one on Ebay for $200 bucks! I want to do the best restoration I possibly can on it. The cabinet is in good shape as is the chassis. However there are several areas on the chassis with a fair amount of rust on it. I want to clean off the rust and my question is. What is the correct finish for the chassis? Were they plated with something? The chassis on the two 70's I have are a dull lead gray color, was this the color when new or were they shiny? Is it acceptable to paint the chassis? If so, is there a paint/color that closely approximates the original finish?
I guess I just want to do what is considered correct, so any input would be greatly appreciated. Thanks!
Kevin
Only my opinion, but the early sets chassis almost look like they were a parkerized finish, similar to what you would see on some military weapons.
Arran. As always, the information you have provided is very valuable to me. Thank you. Yes, it is a Canadian Philco 316A...RadioSvit — 04:04 PM
Best to use the one from the library on this site, then when you refer to part 30 we know which part you are referring t...RodB — 03:32 PM
52-942
Welcome to the Phorum, Ken! The included schematic for your set is located in the Philco Library at the bottom of our Ho...GarySP — 03:13 PM
Video Source for Predicta
You can also source a used VCR and use that as a modulator to feed your DVD source into.TV MAN — 02:57 PM
52-942
Just received my 52-942. Its a handsome set. When I opened the back to examine it I noticed there are not connecting wir...Ken Arroyo — 02:54 PM
"Your radio tubes get these voltages from the power transformer secondary windings. The A voltage is supplied by th...osanders0311 — 01:40 PM
Please correct me if I am wrong, while working on this radio I noticed under the chassis where the bottom of the tubes p...osanders0311 — 01:28 PM
"BTW there's a 2.2k resistor from B+ to one of the XXL tubes so you have to identify those resistors before you rep...osanders0311 — 01:04 PM
BTW there's a 2.2k resistor from B+ to one of the XXL tubes so you have to identify those resistors before you replace t...RodB — 11:08 AM
Okey dokey, let's get on the wayback machine. Back when radios were running on batteries, they were powered by three DC ...RodB — 10:34 AM
There are currently 800 online users. [Complete List]
» 1 Member(s) | 799 Guest(s)
