Refinishing opinions
OK I am a total Noob when it comes to refinishing cabinets, I'll admit it right up front Icon_lol . I need some expert advice. I have a Grunow cabinet. The sides and face have lacquer chipped and scratched off. The top was pretty bad too. I removed the lacquer on the top and found the wood stained and it appears that very little toner was used in the finishing process. What should I do with the finish I'd really hate to remove all the laquer and respray the entire cabinet, and If I do that I will lose the decals on the face, which are not replaceable. Help!! Icon_smile Thanks, Glenn
Happily back in Illinois..not.
I'm no refinishing expert, but it seems to me that if the finish has a lot of damage, that stripping/refinishing may be the only option. Some fellows are able to selectively repair areas of a cabinet by just prepping and spraying the areas needing it. I tried this method on a 39-6 cabinet and a 40-150 cabinet. They look better than they did, but upon close examination you can tell they have been worked on.
Perhaps you could send Steve Davis a PM and ask his advice? Although, he uses a spray gun instead of the "spray bombs" of aerosol that I use (I don't have a compressor or spray gun setup).
Uh, Glen.... what's a noob?
I've been told that when you use paint remover, you can protect the decal and its surrounding and then try to match the old and new finishes.
I've also been told some people do custom water slide transfers.
but I haven't done any of those; on my recent radio I decided to refinish, I ended up removing the decal.
-Mars
Hi Guys,
Tom, Noob=Newbie...lol.
Thanks for the info, I looked up some info and found a way to "pull" the finish to cover the areas on light damage. I made my first attempt in the side and it came out pretty well. I, of course, didn't take any before pictures to post, but I had my wife and MIL look at the side and they had a hard time finding the repair, So I'm satisfied. I will take some pic's before I do the second side to post a little later.
I will post the link for the repair info too, as soon as I find where I stuck it in my favorite's, Icon_rolleyes .
Glenn
Gotcha! Icon_clap
Road Trip for a Philco 46-480
Good morning, folks! I’ve finished the cabinet and the electrical restoration, and have detailed those in their respecti...jrblasde — 10:56 AM
Arran, Thanks for checking you manuals. I appreciate that. Let me know what you find. PhilPdouglaski — 08:46 AM
I have some car radio service manuals, Riders I think (not to be confused with the big blue binders), so I may see if on...Arran — 01:20 AM
Philco model 40-100
Greetings; Here is an update, I found a listing on fleabay for a similar chassis to yours, and it has a photo of what...Arran — 12:58 AM
Philco model 40-100
Greetings; I think I may have found a clue as to what is missing, from a search I made, there is a rear view of the c...Arran — 12:12 AM
Philco model 40-100
I recently acquired a Philco model 40-100 farm (battery) radio. The radio was in very good condition except the red on f...mhamby — 05:59 PM
Hello, Richard the radio is an AC-2687 Studebaker model. The Philco model is S -5323 and the chassis p/n is S-5523Pdouglaski — 11:52 AM
48-482 rear panel help
The 48-482 is an AC only set as well, featuring a power transformer. While the transformer shouldn’t get “hot”, it is ye...jrblasde — 11:12 AM
I gave a Chrysler/MoPar car radio from 1954, it was made by Philco, and it uses two chassis, one has the power supply an...Arran — 11:06 AM
Hello keithchip. You could make a hardboard back for the set, but make sure you provide plenty of ventilation holes in ...GarySP — 11:04 AM
There are currently 2355 online users. [Complete List]
» 2 Member(s) | 2353 Guest(s)
