46-420 Code 125 Replacing Cap with wire coil
I am in the process of recapping this "Hippo" and ran across this cap with wire coiled around it. It is an original Philco cap stamped with .2mfd 400 wv.
Here is a picture of the cap.
Can I use just a regular .22 mf mylar cap to replace and what do I do about the coil?
Thanks- this is my first post here so I hope I did this correctly,
Frank
Hi,
We've been discussing this same part in this thread:
http://philcoradio.com/phorum/showthread.php?tid=3609
Hopefully this will help you as well.
Thanks Ron, I may try just replacing with .22 leaving the coil off and see if it creates any problems. If it does I'll have an idea what might be causing them.
Frank
48-482 rear panel help
Hi Keith, here is an article that covers different FM detector circuits including a section on the theory and alignment ...462ron — 08:26 AM
Well then Dan I guess this old man’s memory wasn’t too foggy :lolno: although I couldn’t remember where I saw that upgra...462ron — 08:08 AM
Need Help to ID this radio 11 tube Philco
Fortunately, I did not have to do much to my GE S-22 (RCA R7A) Almost all caps and the 2 audio transformers packed into...MrFixr55 — 07:44 AM
Yup Arran is correct it is missing the pushbutton covers. I don't know where they all go but it's a common issue on this...Radioroslyn — 06:48 AM
I also have one of these, again it never had a back, and no trace of one. I have been told that the pushbuttons used to ...Arran — 03:29 AM
Thanks Joseph. Hope you get to restore your 48-482 before too long!keithchip — 02:12 AM
RCAs ain't no cake either.morzh — 10:32 PM
After a couple of days worth of troubleshooting my signal generator, I gave up. The oscilloscope still worked fine, so I...jrblasde — 09:51 PM
Yes, I can confirm. I bought one (haven’t restored it yet) which didn’t have a back panel.jrblasde — 09:37 PM
Try a 39-116.Radioroslyn — 09:24 PM
There are currently 903 online users. [Complete List]
» 2 Member(s) | 901 Guest(s)
