1930's Philco Steel Tube Shields-Were they plated?
Hi all, Have numerous Philco tube shields for radios I'm working on from the 30's. Seems like I read some info some time ago that they were plated with zinc or a zinc alloy. Can anyone confirm this and has anyone "restored" these shields so they look close to what they were like when new? Thanks, Ken Kidd
Most likely just galvanized if that. Just make sure that the base still conducts with the sleeve if you paint 'em.
Actually, yes, they were plated...with tin.
You can get by with painting them, if you use Krylon Satin Nickel. The Satin Nickel is conductive!
Thanks for the info-will try the Krylon and see how one turns out. Ken
48-482 rear panel help
Hi Keith, here is an article that covers different FM detector circuits including a section on the theory and alignment ...462ron — 08:26 AM
Well then Dan I guess this old man’s memory wasn’t too foggy :lolno: although I couldn’t remember where I saw that upgra...462ron — 08:08 AM
Need Help to ID this radio 11 tube Philco
Fortunately, I did not have to do much to my GE S-22 (RCA R7A) Almost all caps and the 2 audio transformers packed into...MrFixr55 — 07:44 AM
Yup Arran is correct it is missing the pushbutton covers. I don't know where they all go but it's a common issue on this...Radioroslyn — 06:48 AM
I also have one of these, again it never had a back, and no trace of one. I have been told that the pushbuttons used to ...Arran — 03:29 AM
Thanks Joseph. Hope you get to restore your 48-482 before too long!keithchip — 02:12 AM
RCAs ain't no cake either.morzh — 10:32 PM
After a couple of days worth of troubleshooting my signal generator, I gave up. The oscilloscope still worked fine, so I...jrblasde — 09:51 PM
Yes, I can confirm. I bought one (haven’t restored it yet) which didn’t have a back panel.jrblasde — 09:37 PM
Try a 39-116.Radioroslyn — 09:24 PM
There are currently 903 online users. [Complete List]
» 2 Member(s) | 901 Guest(s)
