Model 76 dial cord and stringing question
Hey all!
I just have a quick question. I have to replace the dial cord on my 76. I see the original cord was some sort of braided wire. Is there a good modern substitute? also would like to know if there is a diagram of how the cord is strung anywhere? As always any help is greatly appreciated. Thanks!
Kevin
Can you snap a pic of it? I just did one on a 95 and I think it might be the same. Has two cords one in the front and one in the back. They go around the dial drum and get wound up onto two worm gears one in the front and one in the back. One cord pulls as the other pushes.
It's kind of a pain to restring.The cords are 16" loop to loop and I used steel picture frame wire.
http://www.philcoradio.com/phorum/showth...p?tid=3531
Don't see the 76 listed in the index, but you may be able to find something similar here.
http://www.theoldradiofixerupperguy.com/...0cord.html
Thanks guys! Terry, I think you are right. What you describe sounds just like what I have. I think I have it figured out. I have one cord that is intact for a pattern. I ordered some nylon dial cord from Radio Daze and I will see how that works. If not I will try picture hanging wire like you did. It looks like tons of fun to restring Icon_crazy !
Kevin
Hey Kevin
It's not hard just takes a lot of paitions to get it all together with out it slipping apart. It took me about a hour get it working.
Good luck
I have a 76 on the bench right now so I can get photos/count turns or something if you want.
-Sam T.
Need Help to ID this radio 11 tube Philco
Yes the 16B as morzh pointed out. Specifically its the January 1935 model version of the 16B. There are a couple earli...klondike98 — 11:51 PM
48-482 rear panel help
Welcome to the Phorum, keithchip! How far you take a radio on cabinet restoration is a matter of personal preference. ...GarySP — 11:28 PM
I've recently finished the internal restoration of a locally purchased Philco 48-482. The cabinet is in ok shape except ...keithchip — 10:28 PM
Welcome to the Phorum, Ken! Lots of help here for all of your restoration questions. Take care and BE HEALTHY! - Gar...GarySP — 07:59 PM
Thank you. I went to your online library and found 2 schematics. I will download and compare to components!Ken D. — 06:31 PM
It is a 16B tombstone.morzh — 06:13 PM
David - sorry, I reread your post and finally saw THD - now the % figures make sense. Thanks for explaining. The PSU...EdHolland — 06:06 PM
Hi Everyone, New member but have been reading this for awhile for tips! Vaccum tubes were before my time so bear with ...Ken D. — 06:03 PM
My Philco 37-116 Restore
Thank you MrFixR55, I appreciate your comments very much. I do not detect much hum if any so I will be staying with the ...dconant — 05:15 PM
Hi DConant Yes, you can replace chokes with resistors.  You do stand the risk of increased hum.  the solution is to inc...MrFixr55 — 04:23 PM
