41-608 Record Changer Issues
My BOL changer (Webster 23) has a rubber/metal riveted disc that transfers power from the motor shaft to the phono shaft that turns the gears. The rubber is shot and I cannot figure out how to get these two parts to meet. Has anyone run into this before and if so any suggestions? It is a very strange rubber/metal/rubber disc. All suggestions appreciated.
David,
Those are the idler wheels and there should be 2 of them on that changer. You might be able to resurface them or you can send them off to be rebuilt. West Tech services does this.
Sean
WØKPX
48-482 rear panel help
Hi Kettlechip and welcom to the Phorum. The back panel question is interesting. I have quite a few radios that use pow...MrFixr55 — 08:24 AM
Not too much at all! :lol:  Sounds like you’re just dabbling into the hobby!jrblasde — 07:56 AM
Hi Joseph, Fortunately, Ms. Fixr does not read my computer, or she would warn you against coming to me for sanity ch...MrFixr55 — 07:27 AM
There's a picture of one of the plastic covers in the following thread: I bought a full set of them in 2012 or so fro...klondike98 — 11:15 PM
Good sanity check! You are correct—the first (as in, the most counterclockwise) position is for the push button presets....jrblasde — 11:05 PM
Hi Joseph, First, verify that your band selector is in the correct position for what you want to do. I believe tha...MrFixr55 — 10:59 PM
Got my replacement signal generator in the mail today! I was able to finish alignment of the IF section. I’ve got some t...jrblasde — 09:58 PM
EdHolland. Glad you liked it. Thanks for the supportRadioSvit — 05:24 PM
Great stuff, Peter thank you for posting.EdHolland — 04:06 PM
My Philco 37-116 Restore
The crack goes from almost the bottom of the tube to well past the fat part. It is an ST type tube. The filament is open...dconant — 10:04 AM
There are currently 462 online users. [Complete List]
» 1 Member(s) | 461 Guest(s)
