Antenna choice
Hello,
I have Philco 37-630.. original literature shows that they were sold with the Philco High Efficiency Aerial. Of course I don't have one, is there anywhere to get one ? Or is it even necessary, what would be a adequate antenna for this radio ?
Kurt
Random-wire works fine. As long and as high as possible. You can get some reception even with 10 or 20 feet indoors but a longer outdoor wire will substantially improve DX reception. No need to hunt for the special Philco antenna.
Gotta wonder what the special Philco antenna was. Does anyone know?
-Greg
gvel Wrote:Gotta wonder what the special Philco antenna was. Does anyone know?
I think it was just an antenna "kit", one with a lead in wire, an antenna wire, a pair of insulators, and possibly a lightning arrestor.
I'm pretty new to old radio repair, too. I live on the first floor in an apartment. Does the choice of wire matter or the gage? I've got about 20 feet of old speaker copper wire elevated several feet off of the floor running around my living room. Can I add some smaller gage copper wire to the end to make a longer antenna run? Should it be soldered together? Any other tips you can offer me? Thanks, Tom
Your antenna is indoors, so wire size will not make a difference. If it was outside, a larger wire would be a better idea, since it would hold up better to weather.
No need to solder your splice together, just make sure you have a good connection and tape it. On the other hand, no harm soldering it.
While you're adding length to the antenna, have the radio on and see if there's an improvement.
-Greg
Greg, Thanks a lot for the advice. I'll try that. Tom
EdHolland. Glad you liked it. Thanks for the supportRadioSvit — 05:24 PM
Great stuff, Peter thank you for posting.EdHolland — 04:06 PM
My Philco 37-116 Restore
The crack goes from almost the bottom of the tube to well past the fat part. It is an ST type tube. The filament is open...dconant — 10:04 AM
Where is the crack? A cracked tube that has air inside will turn opaque once turned on. Perhaps it is a scratch, nogt a...morzh — 09:50 AM
I found I have a cracked 6J5 (AVC) tube. Since the tube shields are so tight I must have broke the tube putting the shie...dconant — 05:32 PM
Looks like I made a mistake. I painted my tube shields silver. Now the reception is poor and can't really zero in on mos...dconant — 01:10 PM
Need Help to ID this radio 11 tube Philco
I did R73 RCA. It has a phenolic board with all stuff mounted on it. And the wiring is deep under everything including ...morzh — 10:37 AM
48-482 rear panel help
Hi Keith, here is an article that covers different FM detector circuits including a section on the theory and alignment ...462ron — 08:26 AM
Well then Dan I guess this old man’s memory wasn’t too foggy :lolno: although I couldn’t remember where I saw that upgra...462ron — 08:08 AM
Fortunately, I did not have to do much to my GE S-22 (RCA R7A) Almost all caps and the 2 audio transformers packed into...MrFixr55 — 07:44 AM
