Two More Questions on Philco bakelite caps and values
Working my way through a Philco 19 code 126 and noticed two discrepancies on sealed caps.
1. Cap labeled "4989W" indicated in the Philco workbench reference material as a .09mfd and 200ohm unit, is shown in the code 126 schematic (item 5) as a .09 and 300ohm package. On the code 121 it is shown as a .09 and 200ohm. Go with the 200 ohm?
2. Cap labeled "8174B" indicated in the Philco workbench reference material as a 700pf and .05mfd unit is shown in the code 126 and code 121 schematics (item 8) as a 700pf and .09mfd. Not certain which I should go with on this one. Any suggestions?
Sorry for the "funny face" on item 2, should be an 8 but keeps coming up that way!
Thanks for your help, Jerry
I'd go with the 200 ohm and the 700mmfd and .09/.1
With bypass caps always go larger.
As usual, thanks for the response Terry. Shall go with the .1 and 200 ohm.
Jerry
Restoring Philco 96
Nice one!Stan the Man — 09:37 PM
Restoring Philco 96
I have eventually replaced the speaker and shot the video, which only shows the upper part of the dial as the hum is ver...morzh — 09:24 PM
Rogers Majestic R-646
Kinda weird to see both open Nothing weird if you remember that this radio is about 100 years old  :)Vlad95 — 07:49 PM
I believe I'm making progress, resistors have been rechecked and corrected, removed that ugly blue capacitor and more wi...osanders0311 — 07:38 PM
Thanks Morzh Yes I recapped everything and replaced almost all the resistors as well. I redid #99 with .015 safety ca...bobclausen — 07:11 PM
Well...pull out every single load of the transformer. For every winding. Unsolder if needed. Then re-do your dim bulb....morzh — 07:02 PM
Kinda weird to see both open, but once you get it up and running, really pay attention to your sound. Listen for loud cr...TV MAN — 06:59 PM
Vlad; I was just reminded of something else, I'm not sure why but many Rogers built sets do seem to have open primari...Arran — 04:40 PM
Thanks RpdB I don't think there's much difference with interstage transformers of different models other than dimersion...Vlad95 — 03:27 PM
Vlad; I looks like your set has the same problem that mine did, both a bad output transformer, and a bad audio inters...Arran — 03:21 PM
There are currently 565 online users. [Complete List]
» 2 Member(s) | 563 Guest(s)
