Need Philco 345 readable schematic
I would like to know a source for downloading a readable schematic for a Canadian Philco model 345 code 122 radio.
I have schematics for models 45 but not for 345. Someone has been in the radio and put a 47mf cap in somewhere,and I need to see if I can find out what the right ones are.
Thanks Dan
   Living in Calgary Alberta
Dan
I have the Radio College of Canada schematics on a DVD, which is sold by a collector in Canada.
I looked at the 345 schematic...hard to read, and you can't make out most of the part values, but I compared it against the USA 45 schematic and they are the same.
I'll send you a copy of this schematic if you want it, but like I said, the scan is not very clear.
Thank you Ron.. I do have the same RCC disk and it is not very readable,that is why I put the request on the forum.
I will see if I can decipher the schematic.
Restoring Philco 96
Nice one!Stan the Man — 09:37 PM
Restoring Philco 96
I have eventually replaced the speaker and shot the video, which only shows the upper part of the dial as the hum is ver...morzh — 09:24 PM
Rogers Majestic R-646
Kinda weird to see both open Nothing weird if you remember that this radio is about 100 years old  :)Vlad95 — 07:49 PM
I believe I'm making progress, resistors have been rechecked and corrected, removed that ugly blue capacitor and more wi...osanders0311 — 07:38 PM
Thanks Morzh Yes I recapped everything and replaced almost all the resistors as well. I redid #99 with .015 safety ca...bobclausen — 07:11 PM
Well...pull out every single load of the transformer. For every winding. Unsolder if needed. Then re-do your dim bulb....morzh — 07:02 PM
Kinda weird to see both open, but once you get it up and running, really pay attention to your sound. Listen for loud cr...TV MAN — 06:59 PM
Vlad; I was just reminded of something else, I'm not sure why but many Rogers built sets do seem to have open primari...Arran — 04:40 PM
Thanks RpdB I don't think there's much difference with interstage transformers of different models other than dimersion...Vlad95 — 03:27 PM
Vlad; I looks like your set has the same problem that mine did, both a bad output transformer, and a bad audio inters...Arran — 03:21 PM
There are currently 566 online users. [Complete List]
» 2 Member(s) | 564 Guest(s)
