37-610T
I have been trying to find ONE piece of walnut veneer to do the front of my 37-610T ,sizes seam to be too small, now I have a Atwater Kent 55 [one of several] this is a parts set. It has a piece of walnut veneer the size that would work on my 37-610T, on it's top ,it has started lifting, but in good shape ,can I use it on the 37-610T ? has anyone out there done this? Seams Like I've heard of this being done
I have used saved veneer for several projects. It is hit or miss sometimes. Other times it works. If the type of wood can be sucessfully blended in then go for it.
So, Q1. Does anyone know where to get the spider. Q2. If there is no such place, what material is best? I doubt tin is...morzh — 09:43 PM
Arran The oxidation seems to go deep, a few layers. The break starts right there, but then it will occur on every la...morzh — 07:35 PM
Mike, This is just a thought, the are on the coil where the verdigris (green oxidation is) I wonder if that is where ...Arran — 06:32 PM
Mike; I've made a one or two spiders by using some card stock, and a razor blade, it took more then one try but they ...Arran — 05:48 PM
Philco 91 Restore Code ??
I wondered about that. Wish there was some place local to get this stuff.dconant — 04:20 PM
Philco 89 indicator light.
Bending the lamp bracket (moving the lamp, that is) can possibly change the shape of the pointer a bit, but not its loca...morzh — 04:01 PM
Because the usable power rating of it then is (3,200/20,000)*25W= 4W. Maybe a tad more due to the mass, but not much. Yo...morzh — 03:59 PM
Thank you Dan, that was the trick. I kept trying to rebend the lamp bracket but that wasn't doing anything to help.Jim Dutridge — 02:18 PM
20K 25 watt. I thought it was a 20 watt at first.dconant — 01:37 PM
My Philco 37-116 Restore
Nah, too much and not that important.morzh — 01:33 PM
There are currently 6055 online users. [Complete List]
» 1 Member(s) | 6054 Guest(s)
