Lubricant for Variable Capacitor
What is a good lubrication for the tuning cap?
Is there something I can use that's readily available, like petroleum jelly, or does Radio Shack sell something?
Or maybe, an auto parts store?
I'd prefer something that I put in and do not touch it ever again (I am sure the old lubrication was there since the inception - but I washed the cap in the dishwasher so it got stripped off)
I use a bit of white grease myself, for better or worst.
Sewing machine type oil. Careful not to over-do.
I use Lubriplate - a white grease.
Chuck
TimC Wrote:Sewing machine type oil. Careful not to over-do.
Same here.
Larry
Than you all guys.
I take it, no one uses WD-40?
Actually, I found yesterday "WD-40 with white grease". What do you think?
There is a can of "Crisco" in my fridge. Use it to season my cast iron skillets.
It's white. Icon_smile
I even came up with a commercial slogan for "Crisco" (hope they see it and pay me for it):
"Crisco! Another white grease!"
PS. Went to automotive store, bought "Liquid wrench" with While Lithium Grease in it.
Worked like a charm. All squeaks and groans are gone!
Than you guys!
Agee with all for once. I use a tiny dot of lithium grease applied with a toothpick and a half a drop of WD40 sprayed in it's cap and applied the same way. Of course I do this after blasting the old crud out of there with deoxit and letting it dry over night. Sewing machine or instrument oil probably just as good.
codefox1 Wrote:I use a tiny dot of lithium grease applied with a toothpick and a half a drop of WD40 sprayed in it's cap and applied the same way.
Actually, there is pre-mixed WD40+White Lithium Grease sold on the same shelf with regular WD40 and the "Liquid wrench" in most hardware / automotive stores.
Restoring Philco 96
Nice one!Stan the Man — 09:37 PM
Restoring Philco 96
I have eventually replaced the speaker and shot the video, which only shows the upper part of the dial as the hum is ver...morzh — 09:24 PM
Rogers Majestic R-646
Kinda weird to see both open Nothing weird if you remember that this radio is about 100 years old  :)Vlad95 — 07:49 PM
I believe I'm making progress, resistors have been rechecked and corrected, removed that ugly blue capacitor and more wi...osanders0311 — 07:38 PM
Thanks Morzh Yes I recapped everything and replaced almost all the resistors as well. I redid #99 with .015 safety ca...bobclausen — 07:11 PM
Well...pull out every single load of the transformer. For every winding. Unsolder if needed. Then re-do your dim bulb....morzh — 07:02 PM
Kinda weird to see both open, but once you get it up and running, really pay attention to your sound. Listen for loud cr...TV MAN — 06:59 PM
Vlad; I was just reminded of something else, I'm not sure why but many Rogers built sets do seem to have open primari...Arran — 04:40 PM
Thanks RpdB I don't think there's much difference with interstage transformers of different models other than dimersion...Vlad95 — 03:27 PM
Vlad; I looks like your set has the same problem that mine did, both a bad output transformer, and a bad audio inters...Arran — 03:21 PM
There are currently 559 online users. [Complete List]
» 2 Member(s) | 557 Guest(s)
