BOYS AND THEIR TOYS
Well, I know young boys like to play with their toys(like blocks)--but do men? Sometimes yes, sometimes no. For example my radio restorer seems very hesitant to "play" with the blocks on my Philco 38-690 even after I told him people on the Phorum say they are often bad. He's got my radio playing pretty well from what I can hear over SKYPE but is that good enough? He told me: "IN YOUR RADIO ARE 3 BLACK BLOKS : 32-2752 , 6287 SU, 3793DG". I would appreciate opinions from my learned members before this radio gets shipped to me! Thanks much and hope all have a Happy Easter or Passover.
Sam
There is one block in the upper chassis of the 38-690 that absolutely should NOT be touched! It is part (97), and does not contain any capacitors, but instead a coil which is the set's 10 kc audio filter. Unpot that, and you may destroy that coil. That block is part no. 32-2752.
The other two are conventional bakelite block caps, and should be unpotted and the inside replaced with new caps.
Those bakelite cap blocks will test your patience, but if I can do them, anyone can. Just takes time.
Here are the 2 links you need to know about:
http://www.philcoradio.com/tech/blocks.htm
http://www.philcorepairbench.com/capbuild.htm
The bakelite block in my 40-190 was the very first thing I did in the re-build. Heck, haven't gotten much farther than that because nice weather's been taking me outside. Bakelite blocks are not complicated critters, but they do require patience.
And a nice handy guide like the two listed above, plus:
http://www.philcorepairbench.com/bblokcap.htm
Which is essentially the same info but with larger pictures. ;)
Philco 91 code 221
Philco 91 code 221
Hello Keith, great news !! Sincerely Richardradiorich — 02:14 AM
Finally, got the antenna fixed (repaired some broken wires) and have the radio playing. I've got four different schemat...keith49vj3 — 09:38 PM
Bob, Nice radio.  I’ve not seen one before.  Keep us updated!Joe Rossi — 07:56 PM
Phioco 90 Power Transformer Wire Colors
Thanks for adding that information.klondike98 — 06:09 PM
Although I have used this site as a resource for a number of years this is my first post.   I am restoring a Model 90 si...vincer — 05:02 PM
My collection presentation
There is a complete instruction how to solve your problem. One piece of advice - be careful with the low-voltage capacit...Vlad95 — 09:32 AM
Vlad; I thought your brown RCA portable looked familiar, I have one that is very similar, the RCA-Victor model BX-55....Arran — 02:31 AM
