A Philco 118 Chassis
I have no idea why I decided I wanted this, but here it is. Maybe I am going to find a 118B cabinet and speaker????
[Image: http://i1185.photobucket.com/albums/z345...philco.jpg]
Gene
Nice knobs! If you want to make a Frankenradio I've got a 650 cab.
Maybe because the 118 is a pretty good radio! I can not recall ANY 118 that I had not being an excellent receiver.
Terry,
Is your cabinet a table model?
Gene
Hmmm... not sure the 118 control shafts will fit in the model 650 holes.
Mike: if you're reading what I just wrote, don't (heh heh heh) go there....
Philco 60 Squealing
Usually a wave trap is for keeping IF signals from entering the antenna and from leaving the antenna. You feed an IF sig...RodB — 09:30 PM
Philco 60 Squealing
I just peaked it for the best signal at 600. NULL it for IF frequency, originally it would have been null for 500kh...Chas — 08:05 PM
Philco 60 Squealing
Wavetrap no longer matters.morzh — 05:19 PM
Philco 60 Squealing
Rod, I had checked out your suggestions but did not help. I did solder the ground rivets to the chassis as Chas suggeste...dconant — 04:52 PM
37-690 Bass Choke Replacement
Yeah, I know, Mouser and Digikey don't have "big iron" components. For some reason Philco was messing with the...Radiodial — 04:25 PM
Yes, I just had to deal with that while repairing the 37-604 Philco. Exactly that value choke was gone. And the current ...morzh — 03:52 PM
Ah, now where to find one. I've into this before on smaller sets, I now recall. Hammond makes one that is only rated...Radiodial — 03:27 PM
Philco 38-7 Speaker
Ask the admins to put them together. As for the renaming, while inside the thread, you simply press "New reply&quo...morzh — 02:23 PM
This is the parts catalog. 32-7528 choke is 65H, 10mA, 2,250 Ohm inductance. Find a suitable one.morzh — 02:18 PM
While troubleshooting the no bass amplification issue, I think I found the culprit. The choke #104 is reading 164K ohms....Radiodial — 01:42 PM
There are currently 3848 online users. [Complete List]
» 4 Member(s) | 3844 Guest(s)
AvatarAvatarAvatarAvatar
