Philco model 42-350t
#31
It's an 828. I have been looking but have never found another like it.
Eric
The Villages, FL
#32
What a gorgeous unit! Did you have to do any cabinet work on it, or is it the original finish? (Hard to tell from photo).
#33
I stripped it completely and refinished it using stain and finished it with spray cans of gloss lacquer. It was in pretty good shape. Lucky for me, it was my first!
Eric
The Villages, FL
EdHolland. Glad you liked it. Thanks for the supportRadioSvit — 05:24 PM
Great stuff, Peter thank you for posting.EdHolland — 04:06 PM
My Philco 37-116 Restore
The crack goes from almost the bottom of the tube to well past the fat part. It is an ST type tube. The filament is open...dconant — 10:04 AM
Where is the crack? A cracked tube that has air inside will turn opaque once turned on. Perhaps it is a scratch, nogt a...morzh — 09:50 AM
I found I have a cracked 6J5 (AVC) tube. Since the tube shields are so tight I must have broke the tube putting the shie...dconant — 05:32 PM
Looks like I made a mistake. I painted my tube shields silver. Now the reception is poor and can't really zero in on mos...dconant — 01:10 PM
Need Help to ID this radio 11 tube Philco
I did R73 RCA. It has a phenolic board with all stuff mounted on it. And the wiring is deep under everything including ...morzh — 10:37 AM
48-482 rear panel help
Hi Keith, here is an article that covers different FM detector circuits including a section on the theory and alignment ...462ron — 08:26 AM
Well then Dan I guess this old man’s memory wasn’t too foggy :lolno: although I couldn’t remember where I saw that upgra...462ron — 08:08 AM
Fortunately, I did not have to do much to my GE S-22 (RCA R7A) Almost all caps and the 2 audio transformers packed into...MrFixr55 — 07:44 AM
