Threads: 107
City: Sheboygan Falls,Wisconsin
Okay guys, you talked me into it  ! I just got my latest Craigslist find home a few minutes ago. Here are some quick pics. Haven't even had much time to look at it but it looks pretty clean inside. It has a few cabinet issues but nothing I can't fix. Cabinet styling doesn't do much for me but it IS a Mystery Control set and for $65 I'm pretty happy about it  Gotta go and figure out where to put this beast!
Kevin
Those pics were so quick that I completely missed them...
But seriously, congratulations!
Threads: 107
Threads: 573
It is also pretty clean. Congrats!
Threads: 55
City: Evanston, IL
I see the Mystery Control frequency is a Code 6 on the radio chassis rear. Is there a corresponding "6" inside the Mystery Control? If so, then, the MC is the original to the set. Otherwise the MC can be re-tuned to match your set. BatteryMaker, a member here, can provide a repro MC control battery for you.
Good catch,
Chuck
Threads: 107
Yes, there is a number 6 stamped on the serial number label.
Kevin
Threads: 242
City: West Bend, Wisconsin
 Very nice! Congratulations
Threads: 55
City: Evanston, IL
Very nice when you get the set and original control with Mystery sets.
Patience is needed, as you can see from the chassis. ;)
Good luck,
Chuck
Threads: 50
City: Apple Creek
State, Province, Country: Ohio
Kevin,
Nice score! If you need any parts let me know I still have a junk chassis and a bunch of parts from two other chassis that came from a 39-116 and a 40-205 which also were mystery control sets. I have restored a 39-55 and a 39-116 you're going to love replacing all that crumbling wiring.
Threads: 367
City: Dover, OH
Looks quite nice! Congrats on scoring it complete with the controller! I have a mystery control model an old gentleman gave me a few years back, but he never had the control.
Threads: 54
That's not too bad of a find since it has the control box still with it, too bad about the large chip out of the door. With regard to the battery for the control I'm not sure whether Mr. Morris the Batterymaker still makes those, he does still have the artwork however.
(This post was last modified: 06-17-2013, 08:22 PM by Arran.)
Threads: 41
City: Shepherdsville, KY
Hi
Nice Radio,  I have the 39-116 with the remote. I have the radio working I recapped it and replace a lot of the rubber wire.  It is a good reciever and the audio is very good. I think the 39-55 has the same audio as the 39-116.  The 39-116 has a shortwave band and that is the only diff I think. So I think you will like the sound of the radio. I do. I need to get the remote working but I am lazy I guess.  I have to get a battery before I can check it tho.
Joe
Threads: 107
Thanks guys! I'm pretty happy with it overall. The chassis looks to be in very good shape, but I haven't had a chance to pull it out and look underneath yet. I had my first taste of replacing crumbling wire with my 40-150 so not in much of a hurry to start on this one! May be a winter project. The cabinet does have some veneer issues, but I enjoy working on the cabinets anyway, so I pretty confidant I can fix them.
So, I'm just going to clean it up and put it on the back burner for now. I will post some pics of the chassis when I get it out.
Kevin
Threads: 54
No the 39-116 also has a tuned RF amplifier stage, and it has three bands as opposed to the 39-55 which only has the AM broadcast band. Basically the radio section uses six tubes, the remote receiver uses four tubes, and while it has push pull outputs it looks like they used the screen grid inversion trick like they did on the 40-180. One other good thing about this set is that the grille cloth looks like it's in good condition which is always a bonus.
(This post was last modified: 06-18-2013, 10:19 PM by Arran.)
EdHolland. Glad you liked it. Thanks for the supportRadioSvit — 05:24 PM |
Great stuff, Peter thank you for posting.EdHolland — 04:06 PM |
My Philco 37-116 Restore
The crack goes from almost the bottom of the tube to well past the fat part. It is an ST type tube. The filament is open...dconant — 10:04 AM |
Where is the crack? A cracked tube that has air inside will turn opaque once turned on.
Perhaps it is a scratch, nogt a...morzh — 09:50 AM |
I found I have a cracked 6J5 (AVC) tube. Since the tube shields are so tight I must have broke the tube putting the shie...dconant — 05:32 PM |
Looks like I made a mistake. I painted my tube shields silver. Now the reception is poor and can't really zero in on mos...dconant — 01:10 PM |
Need Help to ID this radio 11 tube Philco
I did R73 RCA. It has a phenolic board with all stuff mounted on it.
And the wiring is deep under everything including ...morzh — 10:37 AM |
48-482 rear panel help
Hi Keith, here is an article that covers different FM detector circuits including a section on the theory and alignment ...462ron — 08:26 AM |
Well then Dan I guess this old man’s memory wasn’t too foggy :lolno: although I couldn’t remember where I saw that upgra...462ron — 08:08 AM |
Fortunately, I did not have to do much to my GE S-22 (RCA R7A) Almost all caps and the 2 audio transformers packed into...MrFixr55 — 07:44 AM |
