Mystery Cap in 42-327
Right John, the 1st IF has pin 7 and 5 tied together like the schematic. I saw it on the print but it never registered... But this set had been messed with by someone at some point in its life.
Here’s what bothers me about saying a radio works. What I would like is a benchmark. A spec. that says for instance, you put 10 microvolts on the antenna input at 1000 Khz and you should measure 5 watts out across the speaker. Nevermind I don’t have a way to generate 10 microvolts. I just need some reliable benchmark to say I’ve done all I can do to make it work as well as it did originally.
I live 60 miles from the metro area (yeah I'm retired and I love it) and out here we have 3 or 4 local stations running between 1000 and 5000 watts (daytime) – maybe 10 to 20 miles away. Even they don’t seem to come in well.
I have an old TV aerial on top of the barn that I use to connect to the radios. But that is cheating. Does anyone have a way they benchmark their sets???
Philco model #20
Hello again fellows , well I powered up the set this evening after I had changed every cap and resistor in this set and ...onlyrick — 09:34 PM
Yes - better it happened on the repair bench than returning to the owner. The other question is - do I also dissect a...EdHolland — 09:08 PM
That's a bummer but get them now. Paul BPaul Philco322 — 08:27 PM
I completed the insulation on the cabinet interior (Al foil and hi temp silicone rubber), and reglued the speaker gasket...EdHolland — 06:18 PM
Tim - Photos of 8 octal tube sockets. (Top and bottom) Send me a PM if you're interested.RodB — 04:11 PM
VTVM meter moves when my hand is next to it & not on
Haha! I hope so. It seemed rather lost and forgotten languishing in the frozen Northeast of England.EdHolland — 02:36 PM
Ed - it's in the Cayman's enjoying the good life.RodB — 02:14 PM
Static electricity - but the other chaps beat me to it again. I've seen this before with analogue meters. I've also ...EdHolland — 01:56 PM
There are currently 1200 online users. [Complete List]
» 6 Member(s) | 1194 Guest(s)
AvatarAvatarAvatarAvatar
