Philco 39-45 Push Buttons
I pulled the chassis out of the cabinet this morning to clean and lubricate the push button deck and found something that made me pretty happy. The preset station coil that I thought was missing, isn't. Someone had "adjusted" the slug all the way in until it fell out the front end. Icon_wtf (herp derp) It was just a matter of fitting it back into the coil and reversing the screw until it was returned to its proper place. Now I have all 8 preset stations.
While I had it out, I went ahead and replaced the formerly rubber-insulated wires on the preset assembly. I'm also going to touch up the dial glass paint before everything goes back in.
I know this thread is a bit old, just wondering if the OP found a solution for the loose buttons?
I have the same problem, and also believe that I have installed them correctly.
There are a couple of photos here; http://antiqueradios.com/forums/viewtopi...6&t=301602
Thanks
Russ
Sorry about getting back so late on this.
To answer your question:
The solution was to just quit worrying about it.
They wiggle. Meh.
Thanks for the link to your pics. They confirm the position I thought they were supposed to be in.
I think it looks pretty good, I like the angles, very 40's to me. Enjoy.
These buttons would have looked really spiffy had they been back lit.
Philco missed out on a chance to jazz up this set.
(08-26-2016, 11:56 AM)Eric T Wrote:  These buttons would have looked really spiffy had they been back lit.
 Well, one could always rig up a warm white LED behind the pushbuttons running off the 6.3 volt filament winding, something easily removable, and which would not add too much extra of current load to the winding.
Hmmmmm......
Very interesting idea.
Need Help to ID this radio 11 tube Philco
Welcome, the radio looks intimating 11 tubes, wish you well.Jimradio — 07:49 AM
Hi Dan, it’s been 10 years since I restored the electronics on my 37-116 so I’m going on some foggy memories. I remember...462ron — 07:37 AM
Yes the 16B as morzh pointed out. Specifically its the January 1935 model version of the 16B. There are a couple earli...klondike98 — 11:51 PM
48-482 rear panel help
Welcome to the Phorum, keithchip! How far you take a radio on cabinet restoration is a matter of personal preference. ...GarySP — 11:28 PM
I've recently finished the internal restoration of a locally purchased Philco 48-482. The cabinet is in ok shape except ...keithchip — 10:28 PM
Welcome to the Phorum, Ken! Lots of help here for all of your restoration questions. Take care and BE HEALTHY! - Gar...GarySP — 07:59 PM
Thank you. I went to your online library and found 2 schematics. I will download and compare to components!Ken D. — 06:31 PM
It is a 16B tombstone.morzh — 06:13 PM
David - sorry, I reread your post and finally saw THD - now the % figures make sense. Thanks for explaining. The PSU...EdHolland — 06:06 PM
Hi Everyone, New member but have been reading this for awhile for tips! Vaccum tubes were before my time so bear with ...Ken D. — 06:03 PM
There are currently 376 online users. [Complete List]
» 3 Member(s) | 373 Guest(s)
