push pull vs single ended
Hi All;
I am going to repeat my question that I stated in my wanted philco 45 audio transformer section, just in case It did not get noticed..
Can a Push-pull Transformer be used in a Single ended transformers place ?? If the impedence matches..
Or is the windings on the push-pull transformer on each side wound opposite of each other ??
I can get a universal push-pull transformer that matyches my impedience for my 42 tube, but not a single ended transformer that will match perfectly its impedence..
THANK YOU marty
Yes, radio output tubes are not all that fussy about impedence matching, you would be good with anything from 4 to 8K to your speaker load for single ended 42. If you have a Push-Pull that has a primary in this range, you can use it, just tape up the middle tap of the primary, or just use one leg of the primary if it is a closer match. Any slight mismatch would only minimally affect the volume and would not cause any harm. Anyway, if you are not happy, you can always change it out for another one.
Hi All;
CodeFox, Thank You for your prompt reply.. I was hoping that it would be OK to use a Push-Pull transformer..
I have contacted Gary at OldRadioParts and the first two I wanted He had already Sold, So I sent Him some more numbers and I am awaiting a reply from Him.. Otherwise I can get a Universal PushPull from Hammond..
THANK YOU marty
No you cannot use the same size/power pushpull instead of SE. It will saturate. At best you will have your sound degraded, at worst you will screw up your tube.
However if the transformer is oversized or air-gapped (possibly) then you may use push-pull type, but it does need to be oversized.
philco predicta
Philco 91 code 221
Philco 91 code 221
Philco 91 code 221
Hello Keith, great news !! Sincerely Richardradiorich — 02:14 AM
Finally, got the antenna fixed (repaired some broken wires) and have the radio playing. I've got four different schemat...keith49vj3 — 09:38 PM
Bob, Nice radio.  I’ve not seen one before.  Keep us updated!Joe Rossi — 07:56 PM
Phioco 90 Power Transformer Wire Colors
Thanks for adding that information.klondike98 — 06:09 PM
Although I have used this site as a resource for a number of years this is my first post.   I am restoring a Model 90 si...vincer — 05:02 PM
