bakelite blocks philco 37-630
Want to re-cap the bakelite blocks on a 630 chassis.
As far as I can tell from the schematics, it should have 2 blocks.
THe first one I removed is labeled (I believe) 8378 su.
Has a single cap inside, whereas the schematics say it has two .015 caps.
What gives?
I have .010 and .020 caps.
Should I default higher or lower?
murf
murf, I sent you a PM on the other site. Anyway, I don't think that 8378 is a good number. Probably 8328 which is a single .03 capacitor.
If you are looking at the 2 (each) .015 caps that go across the AC line, they must be safety caps (X1 - Y2 or X2 - Y2). And you are probably going to find .01 replacements.
Well guy's, It looks to me like someone added a block down at the bottom or back side of the chassis.
Nothing shown there on the parts list diagram.
THe power cord is supposed to be wired to the block that is shown on the parts list diagram.
Looks like they added a second block and wired the power cord to that one.
They also did some jerry rigging when they replaced the electrolitics.
Anyway, I replaced the double caps in both blocks and still have the slight distortion.
In fact I now have a squeal if I turn it all the way up on the volume.
THere are a couple caps I could still replace if I dig enough.
Seems to pick up lots of stations, just has a distortion problem.
Tested all tubes and replaced a couple with no luck.
Tried adjusting the alignment a little, but no luck.
Any suggestions from the experts?
Thanks and have a great weekend.
murf
Just Radios has 0.015uF safety caps if you need them.
Why safety caps?
In other words the .02 630 volt caps I put in, need to be replaced?
Could that be causing the squeal at high volume?
murf
Here's the ABC's of safety caps found on the Just Radios site. http://www.justradios.com/safetytips.html
No, no squeal from them.
Yes, either replace them or delete them.
Check the volume control. It can often have an open tap or intermittent causing these problems.
hello mr Fixr, for sure !! I have some radios that I need to make some batteries for too. Sincerely richardradiorich — 12:33 AM
Dittos, sweet b on the battery. Love the "9 Lives" logo, remembered from my childhood. Other neat ones are t...MrFixr55 — 11:24 PM
Hi Morzh, Dunno if the AC EMI caps are an issue. I never liked the concept but never had an issue with these causin...MrFixr55 — 11:21 PM
And no hum without the 7AF7? Not common but I am thinking heater - cathode short. This would introduce hum in this sta...MrFixr55 — 11:14 PM
schematics
Those filter caps in the cardboard tube are easy to restuff, especially the kind with the rolled over end. You don't hav...Arran — 09:56 PM
If you have 5 wires, do this: The wires that go to thick-wire wound winding are the filament. If you do not know wha...morzh — 09:03 PM
I recently acquired a Philco Model 16 Code 126. I removed the power transformer to place heat shrink on some very bad...bobclausen — 08:23 PM
Hello Bob, That battery looks great nice job ! Sincerely Richardradiorich — 08:20 PM
Yes, I plan to put a Velcro closer on the top.klondike98 — 07:28 PM
Nice job on the battery, Bob. Can the box be opened to replace the 9 volters?RodB — 11:32 AM
