Philco 91 Tube Shield
I am looking for a ganged tube shield for a Philco 91. I have seen other tube shields that look like they may work. I was wondering for those that my have seen a model 91 tube shield if you could tell me how many dividers are in the original 91 tube shield. I believe there may be two which would be three compartments but then there could be three dividers which would be four compartments.
Charlie
Hi Charlie,
Here is a picture of the tube shield from the 91 I am working on. it has two dividers as you can see. hope it helps!
Kevin
[Image: http://i1160.photobucket.com/albums/q500...932ffa.jpg]
schematics
Those filter caps in the cardboard tube are easy to restuff, especially the kind with the rolled over end. You don't hav...Arran — 09:56 PM
If you have 5 wires, do this: The wires that go to thick-wire wound winding are the filament. If you do not know wha...morzh — 09:03 PM
I recently acquired a Philco Model 16 Code 126. I removed the power transformer to place heat shrink on some very bad...bobclausen — 08:23 PM
Hello Bob, That battery looks great nice job ! Sincerely Richardradiorich — 08:20 PM
Yes, I plan to put a Velcro closer on the top.klondike98 — 07:28 PM
Nice job on the battery, Bob. Can the box be opened to replace the 9 volters?RodB — 11:32 AM
Thank you for the detailed response MrFixr. To clarify, the hum starts when the tubes are fully warmed up, and goes a...sq65 — 09:15 AM
MrFixr The chassis, if there is no ground pin in the AC plug, due to the Y-caps from L/N to the chassis, is at 60VAC re...morzh — 08:47 AM
schematics
thanks I'll try the polar caps seperatelymseno — 07:38 AM
Hi SQ55, A strange issue indeed!  Just so I have you straight, on a dim bulb you get normal operation after the set warm...MrFixr55 — 12:44 AM
There are currently 725 online users. [Complete List]
» 3 Member(s) | 722 Guest(s)
