37-620 RF Transformer
I have a 37-620 that was working after restoration but now the broadcast band is down. I isolated it to the RF transformer part number 32-2108. The primary appears to be open. I have no experience with winding transformers with mag. wire.
Is there a place to buy the part? If not are there step by step instructions for winding your own? Also would a different RF transformer part number work as well?
Thanks for any help
Check here: http://www.philcoradio.com/resourceb.htm#v
and you can put a Wanted Post up in case someone on the Phorum has one.
And no hum without the 7AF7? Not common but I am thinking heater - cathode short. This would introduce hum in this sta...MrFixr55 — 11:14 PM
schematics
Those filter caps in the cardboard tube are easy to restuff, especially the kind with the rolled over end. You don't hav...Arran — 09:56 PM
If you have 5 wires, do this: The wires that go to thick-wire wound winding are the filament. If you do not know wha...morzh — 09:03 PM
I recently acquired a Philco Model 16 Code 126. I removed the power transformer to place heat shrink on some very bad...bobclausen — 08:23 PM
Hello Bob, That battery looks great nice job ! Sincerely Richardradiorich — 08:20 PM
Yes, I plan to put a Velcro closer on the top.klondike98 — 07:28 PM
Nice job on the battery, Bob. Can the box be opened to replace the 9 volters?RodB — 11:32 AM
Thank you for the detailed response MrFixr. To clarify, the hum starts when the tubes are fully warmed up, and goes a...sq65 — 09:15 AM
MrFixr The chassis, if there is no ground pin in the AC plug, due to the Y-caps from L/N to the chassis, is at 60VAC re...morzh — 08:47 AM
schematics
thanks I'll try the polar caps seperatelymseno — 07:38 AM
There are currently 744 online users. [Complete List]
» 1 Member(s) | 743 Guest(s)
