Philco 37-10
In restoring a Philco 37-10 I find that the 6H6G discriminator tube is not wired as shown on the schematic. The connections to the plates and cathodes are reversed; my set has the plates going to 2 meg resistors 60 and 61, and the cathodes going to coil 48. The schematic shows it the other way around. Is this a drawing error, or a modification? I hope someone can shed some light on this. I just today got the radio to playing (it seems to play well), and have not yet reassembled the Magnetic Tuning apparatus (I need a new dial from Mark Oppat.) Thanks for any help. Charrday
I moved this thread to the restoration forum. Seems more appropriate.
-Keith
Do you have a pic of how your radio is currently hooked up. This radio 37_10 I was told is like the mod in my 38_15.
I think its a known mod based on this service bulletin:
[Image: https://dl.dropboxusercontent.com/u/54621529/37-10.jpg]
You can see the full bulletin in the 1937 section listed as "Changes: July 1937" http://www.audiophool.com/Philco.html
Running changes to Philco sets made between 1933 and 1938 are available here:
http://www.philcoradio.com/phorum/showth...hp?tid=215
Look for the file changes.zip .
Darn...Ron,I forgot that was in the download files Icon_sad
Welcome to the Phourm!!!
Enjoy! lot's of help and smart guy's and girl.
Thanks. I'm not new to radio restoring, but, like an old magazine, an old radio I've not worked on before is new until I become familiar with it.
schematics
Those filter caps in the cardboard tube are easy to restuff, especially the kind with the rolled over end. You don't hav...Arran — 09:56 PM
If you have 5 wires, do this: The wires that go to thick-wire wound winding are the filament. If you do not know wha...morzh — 09:03 PM
I recently acquired a Philco Model 16 Code 126. I removed the power transformer to place heat shrink on some very bad...bobclausen — 08:23 PM
Hello Bob, That battery looks great nice job ! Sincerely Richardradiorich — 08:20 PM
Yes, I plan to put a Velcro closer on the top.klondike98 — 07:28 PM
Nice job on the battery, Bob. Can the box be opened to replace the 9 volters?RodB — 11:32 AM
Thank you for the detailed response MrFixr. To clarify, the hum starts when the tubes are fully warmed up, and goes a...sq65 — 09:15 AM
MrFixr The chassis, if there is no ground pin in the AC plug, due to the Y-caps from L/N to the chassis, is at 60VAC re...morzh — 08:47 AM
schematics
thanks I'll try the polar caps seperatelymseno — 07:38 AM
Hi SQ55, A strange issue indeed!  Just so I have you straight, on a dim bulb you get normal operation after the set warm...MrFixr55 — 12:44 AM
There are currently 752 online users. [Complete List]
» 1 Member(s) | 751 Guest(s)
