40-201 SW antenna connection
It has been quite a while since I took the chassis out of the 40-201 cabinet. Today I brought the 38-9867 SW antenna in and connected it to the chassis to use it in checking the SW high band. It works, but I connected one end to a ground lug at the antenna terminal strips on the back of the set. The existing ground lead is so short on this loop antenna that it appears only capable of attachment to one of the screws on a bracket at the tuning capacitor which holds the capacitor in position on the chassis. I think I am correct about that.
I don't think it is critical as it seems to be working OK on the bench using a clip lead back to the terminal strip ground.
I have one question about this SW high band. Has anyone used a long-wire or other outside antenna connected in a way to improve SW reception on this band? It may be that this particular loop is optimized for the front end. If an outside antenna connection is desired, it may be necessary to make a similar loop next to the existing one to couple the energy into the original loop. Does anyone have any experience with this?
Joe
I forgot to make mention of it the other day, but last week I corrected another error on my schematic (applies to both R...jrblasde — 09:27 PM
Gloritone 27 Radio
Restoring Philco 96
Restoring Philco 96
Restoring Philco 96
Restoring Philco 96
Nice find! I hope it completes your console.jrblasde — 08:45 AM
Gloritone 27 Radio
Hello john, That, is the first time I have have seen or heard of that brand and model. Welcome to the party !! Sincer...radiorich — 08:08 AM
Thank you! I’ll probably use the half-round molding and tone it to match the original. Thanks for the replies!Max T — 06:34 AM
Gloritone 27 Radio
I'm kind of late to this thread, but Buzz1151 has a 3 part restore series on the model 27: A little bit of extra t...Eliot Ness — 05:48 AM
You can get half-round moulding in various diameters at any home improvement store. That way the flat edge is uniform. ...GarySP — 12:03 AM
There are currently 1857 online users. [Complete List]
» 1 Member(s) | 1856 Guest(s)
