plate detector bypass cap
Well, I was suspicious of that correction we made to the sch of 90 making the caps in that Plate detector circuit 35pF - I thought it was not sufficient so I kept the cap thwt was there which is 350pF and the other cap after the choke I also made 350pF, as it was originally in the schematic.
Now, when it comes to the first cap it is the plate bypass cap and it is recommended in Plate Detectors to be chosen like follows below:
(From Wikipedia)
>>>>A plate bypass capacitor (usually 500 pF to 0.002 µF for triodes, or 250 pF to 0.001 µF for tetrodes and pentodes) is used to regulate plate current.<<<
So it makes sense that it was shown 350pF and not 35pF (we have a tetrode). After all the criterion is the impedance of the cap should be small enough for RF while large for audio.
Another source also lists it about 250pF. And the similar values are in the 70 sch, that one which also uses plate detector.
So even though we have a radio which does have 35pF there, maybe there is a good reason there should be 350pF.
I wonder if more people have a 90 with plate detector (especially that with 2x45 output). So we could have more data.
Hi Morzh, May be a good idea to remove the cone to prevent damage. You may have to do so anyway to remove the pole ...MrFixr55 — 08:44 PM
Philco 91 Restore Code ??
I think that Danaher, the company that owns Beckman-Coulter (the company that I worked for 41 years) owns Fluke. They a...MrFixr55 — 08:35 PM
Rod I wish... :lol: I am not sure I'd buy the Fluke, had it not fell in my lap for free. $500 to $800...it's a lot...morzh — 08:09 PM
Mike, ...you get a commission?RodB — 07:52 PM
New member
Hi. I specialize in refurbishing Predictas, but I'm in Chicago. If you can get it to me, I'd be happy to go over it. ...Bob Andersen — 06:43 PM
I have 3 G speaker, all with open Field coils. Today I pull one of the shelf and decided to try to remove the FC (spo...morzh — 06:07 PM
Thanks Mike. I will check them out.dconant — 05:52 PM
There is no such thing as bad Fluke. This said, they are expensive. A Fluke is easily 10x the price of comparable CCC...morzh — 05:45 PM
Hello Mike, Yes, I have 3 Fluke meters one being my first Fluke 77 and other being Fluke 87. My third is Fluke clamp -...radiorich — 05:04 PM
I knew that Fluke was the Cadillac so with that in mind what Fluke would you recommend I get?dconant — 03:53 PM
There are currently 3051 online users. [Complete List]
» 2 Member(s) | 3049 Guest(s)
