Philco AC/DC Pilot Lamps
Can someone tell me the modern substitutes for the dial lamps Philco used for these:
Pilot Lamps AC-DC Chassis
Lamp (Code 121) 34-2063
(Code 122) 34-2477
Thanks
Joe
If the radio uses (any) 6 volt tubes: 250mA
Screw base: 46
Bayonet base: 44
If the radio uses (any) 12 volt tubes: 150mA
Bayonet base: 47, 1847
I imagine Chuck or Ron will know but if you look at the parts list for the 42-327 at http://www.audiophool.com/Philco.html it lists:
Pilot Lamp (6volts-Code 121) 34-2068
Pilot Lamp (115volts-Code 122) 34-2477
not equivalent info but maybe it will help. Are you sure its 2063 and not 2068?
The 2068 equivalent is a #47 ( http://www.philcorepairbench.com/lamps.htm )
(update)
Ron answers the 2477 question here: http://philcoradio.com/phorum/showthread...ht=34-2477. That would be a C-7 style 120volt 7 watt. See http://www.radiodaze.com/category/60.aspx for some (or looks like a hardware store bulb for a candle)
Brenda;
Thanks very much for that information. I was trying to make them out on some poor quality schematics and parts lists.
Bob;
Thank you for the information you provided too. What I read as 34-2063 could very well have been 34-2-68 due to the poor quality of the image I was looking at.
Joe
What radio are you working on?
First Radio restoration
There are currently 1441 online users. [Complete List]
» 1 Member(s) | 1440 Guest(s)
