KENT 422
I have a Kent 422 ,little metal 4 tube radio ,I 've got it playing,but would like to know if this can be found in "Riders" not a real good preforming set,so far ,has no IF tube? need alinement, IF 455?
I don't see it in Rider Vol 1-23, nor in Beitman. Seems it may be a tough schematic to find; the Radiomuseum is looking for one: http://www.radiomuseum.org/r/kent_422.html
This fellow has one, you might try emailing him: http://web.eecs.umich.edu/~srs/Antiques/
That looks like a re-badged Arvin.
Have a look at this:
http://www.nostalgiaair.org/PagesByModel...012516.pdf
I think this is an Arvin radio, THANKS for the tip on the schematic BRENDA that sure looks like my radio! I got it to play somewhat better got it tracking good ,loose the signal on lower end,mixer/detector problem?
This radio plays like it looks CHEAP! ,I think by using the name KENT they though they could cash in on the ATWATER KENT name ,but AK never built anything this cheap!
In a Russian prison/criminal argot "Kent" means "a pal". Icon_smile
Bill,
These sets are a bit tricky to align properly, and if not done right, you won't have any low end at all.
You pretty much have to ignore the dial calibration on the low end of the dial. Set your signal generator to 600 KHz then find the signal on the radio. Once you find it, you need to tweak the outer rotor plates on the antenna section. By pulling the cutout sections out a bit or pushing them in a bit, you'll change the resonance of the antenna section to bring it into alignment with the LO. Then use the trimmer on the tuner to bring both the LO and Antenna to match the dial at about 1400 KHz. You may have to do this several times.
How did they calibrate it at the factory? Same way?
Arran. As always, the information you have provided is very valuable to me. Thank you. Yes, it is a Canadian Philco 316A...RadioSvit — 04:04 PM
Best to use the one from the library on this site, then when you refer to part 30 we know which part you are referring t...RodB — 03:32 PM
52-942
Welcome to the Phorum, Ken! The included schematic for your set is located in the Philco Library at the bottom of our Ho...GarySP — 03:13 PM
Video Source for Predicta
You can also source a used VCR and use that as a modulator to feed your DVD source into.TV MAN — 02:57 PM
52-942
Just received my 52-942. Its a handsome set. When I opened the back to examine it I noticed there are not connecting wir...Ken Arroyo — 02:54 PM
"Your radio tubes get these voltages from the power transformer secondary windings. The A voltage is supplied by th...osanders0311 — 01:40 PM
Please correct me if I am wrong, while working on this radio I noticed under the chassis where the bottom of the tubes p...osanders0311 — 01:28 PM
"BTW there's a 2.2k resistor from B+ to one of the XXL tubes so you have to identify those resistors before you rep...osanders0311 — 01:04 PM
BTW there's a 2.2k resistor from B+ to one of the XXL tubes so you have to identify those resistors before you replace t...RodB — 11:08 AM
Okey dokey, let's get on the wayback machine. Back when radios were running on batteries, they were powered by three DC ...RodB — 10:34 AM
There are currently 849 online users. [Complete List]
» 1 Member(s) | 848 Guest(s)
