  • 1 Vote(s) - 1 Average
49-905 Mica Disease-FOUND IT!
Don't worry Don, that kind of stuff never gets thrown out! What size mica cap do I use?
Eric
The Villages, FL
Most of the time 100mmfd will do the trick.
That's one of the problems with repairing those mini IF cans, the values are not marked on the schematic, or rarely are, and not all IF cans used the same value capacitors, sometimes not even the same set. On some you can use 100 mmf/pf, on other you need 120s, others something else.
Thanks guys. It looks like a good project.
Eric
The Villages, FL
[split] New member...
You may have to start further back with your signal injection at the IF signal grid, then tune the second IF transformer...RodB — 10:28 AM
Well, with the replacement tuning assembly, I have finally put the unit back together and aligned the dial.  The first s...HowardWoodard — 01:01 AM
Well, finding a short is easy. Like I said, disconnect the transformer's secondary windings and see if it persists. If...morzh — 09:48 PM
Restoring Philco 96
Nice one!Stan the Man — 09:37 PM
Restoring Philco 96
I have eventually replaced the speaker and shot the video, which only shows the upper part of the dial as the hum is ver...morzh — 09:24 PM
Rogers Majestic R-646
Kinda weird to see both open Nothing weird if you remember that this radio is about 100 years old  :)Vlad95 — 07:49 PM
I believe I'm making progress, resistors have been rechecked and corrected, removed that ugly blue capacitor and more wi...osanders0311 — 07:38 PM
Thanks Morzh Yes I recapped everything and replaced almost all the resistors as well. I redid #99 with .015 safety ca...bobclausen — 07:11 PM
Well...pull out every single load of the transformer. For every winding. Unsolder if needed. Then re-do your dim bulb....morzh — 07:02 PM
Kinda weird to see both open, but once you get it up and running, really pay attention to your sound. Listen for loud cr...TV MAN — 06:59 PM
There are currently 1001 online users. [Complete List]
» 3 Member(s) | 998 Guest(s)
